주요 콘텐츠로 건너뛰기
How to Fix a Small Ceramic Statue
필요한 것
  1. How to Fix a Small Ceramic Statue, How to Fix a Small Ceramic Statue: 1 단계, 이미지 1/1
    • Gather all the pieces and dust them off using the toothbrush. This way there is no stray shards left on the pieces.
  2. How to Fix a Small Ceramic Statue: 2 단계, 이미지 1/1
    • Lay all the pieces on a towel or clean surface, aligned with where they belong. This way it is easy to find what you need in a timely manner.
    • This step is not required but recommended to keep all of the broken pieces organized.
  3. How to Fix a Small Ceramic Statue: 3 단계, 이미지 1/2 How to Fix a Small Ceramic Statue: 3 단계, 이미지 2/2
    • Using the largest piece as the base for the repair, start gluing the pieces back where they belong. Make sure to not overuse the glue, as it can cause issues later.
    • Follow the instructions for the super glue you are using, dampening areas with water if needed.
  4. How to Fix a Small Ceramic Statue: 4 단계, 이미지 1/1
    • As you glue each piece make sure to hold it in place until it solidifies enough to hold everything in place, then glue on the next piece.
    • This step can vary in time. The glue I used required being held in place for a few minutes.
  5. How to Fix a Small Ceramic Statue: 5 단계, 이미지 1/1
    • After you glue it back together, allow it to dry. This way the glue has time to set in place and harden.
    • Make sure your ceramic piece is somewhere stable and dry. If it is not stable it could fall and break again. If the room is not dry the glue could have issues drying properly.
  6. How to Fix a Small Ceramic Statue: 6 단계, 이미지 1/1
    • Finally, lightly sand and paint the areas you glued.
결승점
Trenton Gilbert
회원 가입일: 05/19/20
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 17
30일 전: 68
전체 시간: 1,092
