주요 콘텐츠로 건너뛰기
How to Fix a Small Hole in a Sock
필요한 것
  1. How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: 1 단계, 이미지 1/3 How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: 1 단계, 이미지 2/3 How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: 1 단계, 이미지 3/3
    • Place one end of your thread through the hole of the needle.
    • Wet the end of your thread to make it easier to go through the hole.
    • Pull your thread all the way through and match the ends of the thread together.
    • Tie a knot with the ends of your thread.
    • The needle is sharp. Handle it carefully to prevent poking your fingers or hand.
  2. How to Fix a Small Hole in a Sock: 2 단계, 이미지 1/2 How to Fix a Small Hole in a Sock: 2 단계, 이미지 2/2
    • Insert your tennis ball into the sock until it is lined up with the hole in your sock.
  3. How to Fix a Small Hole in a Sock: 3 단계, 이미지 1/3 How to Fix a Small Hole in a Sock: 3 단계, 이미지 2/3 How to Fix a Small Hole in a Sock: 3 단계, 이미지 3/3
    • Insert your needle into the inside of the sock at the edge of the hole no more than half a centimeter away from the edge.
    • Pull the needle all the way through.
    • If the tail of your thread is too long, trim the excess.
  4. How to Fix a Small Hole in a Sock: 4 단계, 이미지 1/1
    • Insert your needle next to and below where the first insert was.
    • Pull your needle all the way through to create your first stitch.
  5. How to Fix a Small Hole in a Sock: 5 단계, 이미지 1/2 How to Fix a Small Hole in a Sock: 5 단계, 이미지 2/2
    • Insert your needle in the opposite side of the hole and pull to create another stitch.
    • Repeat this step, crisscrossing your stitches until you reach the end of the hole.
    • Keep your stitches loose. You will tighten them at the end.
  6. How to Fix a Small Hole in a Sock: 6 단계, 이미지 1/3 How to Fix a Small Hole in a Sock: 6 단계, 이미지 2/3 How to Fix a Small Hole in a Sock: 6 단계, 이미지 3/3
    • Once you reach the end of the hole, carefully pull on your thread to tighten the stitches together.
  7. How to Fix a Small Hole in a Sock: 7 단계, 이미지 1/2 How to Fix a Small Hole in a Sock: 7 단계, 이미지 2/2
    • To close off the stitch, insert your needle back under all of your stitches and pull out your needle at the top of the repair.
    • Pull your needle through, but not all the way, to create a small loop.
  8. How to Fix a Small Hole in a Sock: 8 단계, 이미지 1/2 How to Fix a Small Hole in a Sock: 8 단계, 이미지 2/2
    • Insert the needle through the small loop.
    • Pull your needle until the loop disappears.
  9. How to Fix a Small Hole in a Sock: 9 단계, 이미지 1/2 How to Fix a Small Hole in a Sock: 9 단계, 이미지 2/2
    • To create a final stitch, insert your needle back under all of your stitches.
    • Pull the thread all the way through.
  10. How to Fix a Small Hole in a Sock: 10 단계, 이미지 1/3 How to Fix a Small Hole in a Sock: 10 단계, 이미지 2/3 How to Fix a Small Hole in a Sock: 10 단계, 이미지 3/3
    • Trim off the excess thread.
    • Remove the tennis ball from your sock.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Yuchen Xu
회원 가입일: 02/03/23
223 평판
안내서 1개 작성함
UC Davis, Team 3-2, Andersen Winter 2023 UC Davis, Team 3-2, Andersen Winter 2023 회원
UCD-ANDERSEN-W23S3G2
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 68
전체 시간: 1,033
