주요 콘텐츠로 건너뛰기
How to Fix a Small Hole in a Sock
필요한 것
  1. How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: 1 단계, 이미지 3개 중 1개 How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: 1 단계, 이미지 3개 중 2개 How to Fix a Small Hole in a Sock, How to Fix a Small Hole in a Sock: 1 단계, 이미지 3개 중 3개
    • Place one end of your thread through the hole of the needle.
    • Wet the end of your thread to make it easier to go through the hole.
    • Pull your thread all the way through and match the ends of the thread together.
    • Tie a knot with the ends of your thread.
    • The needle is sharp. Handle it carefully to prevent poking your fingers or hand.
  2. How to Fix a Small Hole in a Sock: 2 단계, 이미지 2개 중 1개 How to Fix a Small Hole in a Sock: 2 단계, 이미지 2개 중 2개
    • Insert your tennis ball into the sock until it is lined up with the hole in your sock.
  3. How to Fix a Small Hole in a Sock: 3 단계, 이미지 3개 중 1개 How to Fix a Small Hole in a Sock: 3 단계, 이미지 3개 중 2개 How to Fix a Small Hole in a Sock: 3 단계, 이미지 3개 중 3개
    • Insert your needle into the inside of the sock at the edge of the hole no more than half a centimeter away from the edge.
    • Pull the needle all the way through.
    • If the tail of your thread is too long, trim the excess.
  4. How to Fix a Small Hole in a Sock: 4 단계, 이미지 1개 중 1개
    • Insert your needle next to and below where the first insert was.
    • Pull your needle all the way through to create your first stitch.
  5. How to Fix a Small Hole in a Sock: 5 단계, 이미지 2개 중 1개 How to Fix a Small Hole in a Sock: 5 단계, 이미지 2개 중 2개
    • Insert your needle in the opposite side of the hole and pull to create another stitch.
    • Repeat this step, crisscrossing your stitches until you reach the end of the hole.
    • Keep your stitches loose. You will tighten them at the end.
  6. How to Fix a Small Hole in a Sock: 6 단계, 이미지 3개 중 1개 How to Fix a Small Hole in a Sock: 6 단계, 이미지 3개 중 2개 How to Fix a Small Hole in a Sock: 6 단계, 이미지 3개 중 3개
    • Once you reach the end of the hole, carefully pull on your thread to tighten the stitches together.
  7. How to Fix a Small Hole in a Sock: 7 단계, 이미지 2개 중 1개 How to Fix a Small Hole in a Sock: 7 단계, 이미지 2개 중 2개
    • To close off the stitch, insert your needle back under all of your stitches and pull out your needle at the top of the repair.
    • Pull your needle through, but not all the way, to create a small loop.
  8. How to Fix a Small Hole in a Sock: 8 단계, 이미지 2개 중 1개 How to Fix a Small Hole in a Sock: 8 단계, 이미지 2개 중 2개
    • Insert the needle through the small loop.
    • Pull your needle until the loop disappears.
  9. How to Fix a Small Hole in a Sock: 9 단계, 이미지 2개 중 1개 How to Fix a Small Hole in a Sock: 9 단계, 이미지 2개 중 2개
    • To create a final stitch, insert your needle back under all of your stitches.
    • Pull the thread all the way through.
  10. How to Fix a Small Hole in a Sock: 10 단계, 이미지 3개 중 1개 How to Fix a Small Hole in a Sock: 10 단계, 이미지 3개 중 2개 How to Fix a Small Hole in a Sock: 10 단계, 이미지 3개 중 3개
    • Trim off the excess thread.
    • Remove the tennis ball from your sock.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Yuchen Xu
회원 가입일: 02/03/23
232 평판
안내서 1개를 작성함
UC Davis, Team 3-2, Andersen Winter 2023 UC Davis, Team 3-2, Andersen Winter 2023 회원
UCD-ANDERSEN-W23S3G2
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 39
지난 30일: 160
전체 시간: 2,564
