주요 콘텐츠로 건너뛰기
How to Fix a Squeaky Bed Frame
필요한 것
  1. How to Fix a Squeaky Bed Frame, How to Fix a Squeaky Bed Frame: 1 단계, 이미지 1/1
    • Remove anything that is on the bed frame.
  2. How to Fix a Squeaky Bed Frame: 2 단계, 이미지 1/1
    • Shake the bed frame to pinpoint the area of noise.
  3. How to Fix a Squeaky Bed Frame: 3 단계, 이미지 1/1
    • Identify which type of screw the bedframe uses in the given area.
    • You will need to make use of the corresponding screwdriver throughout the guide.
    • Typically, the bed frame will use the same type of screws throughout.
  4. How to Fix a Squeaky Bed Frame: 4 단계, 이미지 1/1
    • Ensure the components of the bed frame are aligned.
    • Identify gaps between parts of the frame.
    • Tighten the screws where gaps are present
    • Sometimes mismatched components cause squeakiness.
  5. How to Fix a Squeaky Bed Frame: 5 단계, 이미지 1/1
    • Tighten the screws within the area of noise.
    • It is recommended to retighten all the screws to avoid any future squeakiness but it is not required.
  6. How to Fix a Squeaky Bed Frame: 6 단계, 이미지 1/1
    • Spray WD-40 into all the contact points of the bed frame.
    • This includes screws and intersections of the frame.
    • Be careful of the spray around children and your eyes.
  7. How to Fix a Squeaky Bed Frame: 7 단계, 이미지 1/1
    • This is an alternative for the previous step.
    • If WD-40 is not available, using a q-tip dipped in a vegetable oil (or a comparable oil that is available) can be used to lubricate the contact points.
결론
Reassemble the bed to your liking.
다른 한 분이 해당 안내서를 완성하였습니다.
Jennifer Nguyen
회원 가입일: 01/20/21
160 평판
안내서 1개 작성함
York University, Team S1-G18, Melo-Thaiss Winter 2021 York University, Team S1-G18, Melo-Thaiss Winter 2021 회원
YORK-MELO-THAISS-W21S1G18
1 회원
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 77
전체 시간: 1,081
