주요 콘텐츠로 건너뛰기
How to Fix a Squeaky Door Hinge
필요한 것
  1. How to Fix a Squeaky Door Hinge, How to Fix a Squeaky Door Hinge: 1 단계, 이미지 1/1
    • Insert the end of the flathead screwdriver into the crease between the top of the pin and the hinge.
  2. How to Fix a Squeaky Door Hinge: 2 단계, 이미지 1/1
    • Take the hammer and hit the handle end of the screwdriver until the pin can be pulled out. This may take a while depending on the door.
  3. How to Fix a Squeaky Door Hinge: 3 단계, 이미지 1/1
    • Place the pin in a bowl of mineral oil (or other household lubricant) and let it rest.
  4. How to Fix a Squeaky Door Hinge: 4 단계, 이미지 1/1
    • Use a brush to apply oil to the empty hinge.
  5. How to Fix a Squeaky Door Hinge: 5 단계, 이미지 1/1
    • Take the pin from the bowl and reinsert it into the door hinge, using a hammer if necessary.
    • Open and close the door a few times. This will help the oil to seep into the cracks of the hinge.
  6. How to Fix a Squeaky Door Hinge: 7 단계, 이미지 1/1
    • Use a towel to catch any drips of oil and to wipe off the hinge.
결론
The door should now be quite silent when opening and closing. Thank you for reading.
다른 3명이 해당 안내서를 완성하였습니다.
Jake Herson
회원 가입일: 03/30/16
219 평판
안내서 1개 작성함
Michigan Tech, Team 1-10, Lauer Spring 2016 Michigan Tech, Team 1-10, Lauer Spring 2016 회원
MTU-LAUER-S16S1G10
1 회원
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 82
전체 시간: 5,014
