주요 콘텐츠로 건너뛰기
How to Fix a Sticking Deadbolt
필요한 것
  1. How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: 1 단계, 이미지 2개 중 1개 How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: 1 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove both of the ¾-inch screws from the strike plate.
  2. How to Fix a Sticking Deadbolt: 2 단계, 이미지 2개 중 1개 How to Fix a Sticking Deadbolt: 2 단계, 이미지 2개 중 2개
    • Remove both of the 2.5 inch mounting screws from the lock cylinder.
  3. How to Fix a Sticking Deadbolt: 3 단계, 이미지 1개 중 1개
    • After all four screws have been taken out, slide the latch of the deadbolt out of the door frame.
  4. How to Fix a Sticking Deadbolt: 4 단계, 이미지 2개 중 1개 How to Fix a Sticking Deadbolt: 4 단계, 이미지 2개 중 2개
    • Spray GumOut parts cleaner at an angle into the latch of the deadbolt.
    • Use a rag to clean and dry off latch.
    • We suggest using GumOut cleaning solutions, which is available at most home improvement stores.
  5. How to Fix a Sticking Deadbolt: 5 단계, 이미지 1개 중 1개
    • Spray GumOut parts cleaner into the key cylinder to lubricate chamber.
  6. How to Fix a Sticking Deadbolt: 6 단계, 이미지 2개 중 1개 How to Fix a Sticking Deadbolt: 6 단계, 이미지 2개 중 2개
    • Insert dry powdered graphite into the key cylinder of the deadbolt.
    • Place the key into the cylinder to lubricate and clean the chamber.
    • If it is difficult to turn the key, then apply more dry powdered graphite into the cylinder.
  7. How to Fix a Sticking Deadbolt: 7 단계, 이미지 2개 중 1개 How to Fix a Sticking Deadbolt: 7 단계, 이미지 2개 중 2개
    • Apply the dry powdered graphite to the latch of the deadbolt.
    • Use a rag to remove excess dry powdered graphite from the latch.
  8. How to Fix a Sticking Deadbolt: 8 단계, 이미지 1개 중 1개
    • Slide the latch of the deadbolt back into the door frame.
  9. How to Fix a Sticking Deadbolt: 9 단계, 이미지 3개 중 1개 How to Fix a Sticking Deadbolt: 9 단계, 이미지 3개 중 2개 How to Fix a Sticking Deadbolt: 9 단계, 이미지 3개 중 3개
    • Take the lock cylinder and the 2.5 inch mounting screws and insert them through the latch of the deadbolt.
    • Then mount the key cylinder on the screws.
    • Use a Phillips screwdriver to tighten the 2.5 inch mounting screws and secure the deadbolt to the frame.
    • The cylinder should be mounted on the outside of the doorframe.
  10. How to Fix a Sticking Deadbolt: 10 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to screw in both of the ¾-inch screws back into the strike plate.
결론
After following this fast fix guide, the sticking deadbolt should be fixed.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Elizabeth Nesler
회원 가입일: 02/23/16
220 평판
안내서 1개를 작성함
Texas Tech, Team 22-5, Rauch Spring 2016 Texas Tech, Team 22-5, Rauch Spring 2016 회원
TTU-RAUCH-S16S22G5
3 회원들
안내서 1개 작성
2가이드 댓글
GumOut Cleaner seems to be initially intended for Brakes and other auto parts. Is that the product you intend?
dan - 답글
Thank you! GumOut worked well. (I was amused to realize I already had it in my shed for cleaning my lawn mowers carburetor.) In my situation the deadbolt wouldn't fully retract with the key any more, but I could push it the rest of the way with my finger. After removing the latch in step 3, I could turn the latch with a flat head screwdriver and find the place where it "sticks." After cleaning the latch out with a few sprays of GumOut and exercising it with a flat head screwdriver, the latch was working smoothly again. Thank you for the helpful guide!
Russ Williston - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 94
전체 시간: 40,732
