주요 콘텐츠로 건너뛰기
How to Fix a Stretched or Loose Canvas
필요한 것
  1. How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: 1 단계, 이미지 2개 중 1개 How to Fix a Stretched or Loose Canvas, How to Fix a Stretched or Loose Canvas: 1 단계, 이미지 2개 중 2개
    • Fill a spray bottle with water at room temperature.
    • In case that you do not have a spray bottle you can use a dishcloth and moisten it.
  2. How to Fix a Stretched or Loose Canvas: 2 단계, 이미지 3개 중 1개 How to Fix a Stretched or Loose Canvas: 2 단계, 이미지 3개 중 2개 How to Fix a Stretched or Loose Canvas: 2 단계, 이미지 3개 중 3개
    • Close the spray bottle tightly.
    • Turn the nozzle to spray.
  3. How to Fix a Stretched or Loose Canvas: 3 단계, 이미지 2개 중 1개 How to Fix a Stretched or Loose Canvas: 3 단계, 이미지 2개 중 2개
    • Put a towel on a flat surface and lay the canvas face down on the towel.
  4. How to Fix a Stretched or Loose Canvas: 4 단계, 이미지 3개 중 1개 How to Fix a Stretched or Loose Canvas: 4 단계, 이미지 3개 중 2개 How to Fix a Stretched or Loose Canvas: 4 단계, 이미지 3개 중 3개
    • Carefully wet the entire backside of the canvas with the spray, or press water onto the canvas with the dishcloth.
    • Only spray until it is damp. Do not soak the canvas.
    • It does not matter if the canvas is new, old, has unfinished artwork or it is completed.
  5. How to Fix a Stretched or Loose Canvas: 5 단계, 이미지 2개 중 1개 How to Fix a Stretched or Loose Canvas: 5 단계, 이미지 2개 중 2개
    • Turn on the dryer so warm air comes out.
  6. How to Fix a Stretched or Loose Canvas: 6 단계, 이미지 3개 중 1개 How to Fix a Stretched or Loose Canvas: 6 단계, 이미지 3개 중 2개 How to Fix a Stretched or Loose Canvas: 6 단계, 이미지 3개 중 3개
    • Blow dry the canvas with a hair dryer on warm until it's completely dry.
    • Keep the hair dryer at least 3 to 5 inches away from the canvas.
    • Do not place the hair dryer directly on the canvas. The heat from the hair dryer can burn the canvas.
  7. How to Fix a Stretched or Loose Canvas: 7 단계, 이미지 2개 중 1개 How to Fix a Stretched or Loose Canvas: 7 단계, 이미지 2개 중 2개
    • Flip the canvas over and check that it is to your liking.
    • Flip the canvas again and double check.
    • Repeat the process again if the canvas is not completely fixed.
결론
If it does not work, you should follow another guide where plaster is used in the canvas.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Eilanis
회원 가입일: 03/18/22
166 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 32
전체 시간: 2,501
