주요 콘텐츠로 건너뛰기
How to Fix a Stuck Auger in a Nama J2 Juicer
  1. How to Fix a Stuck Auger in a Nama J2 Juicer, How to Fix a Stuck Auger in a Nama J2 Juicer: 1 단계, 이미지 3개 중 1개 How to Fix a Stuck Auger in a Nama J2 Juicer, How to Fix a Stuck Auger in a Nama J2 Juicer: 1 단계, 이미지 3개 중 2개 How to Fix a Stuck Auger in a Nama J2 Juicer, How to Fix a Stuck Auger in a Nama J2 Juicer: 1 단계, 이미지 3개 중 3개
    • Find a tool with a small handle that fits in the space under the auger.
    • Example: A dish-washing brush handle.
  2. How to Fix a Stuck Auger in a Nama J2 Juicer: 2 단계, 이미지 3개 중 1개 How to Fix a Stuck Auger in a Nama J2 Juicer: 2 단계, 이미지 3개 중 2개 How to Fix a Stuck Auger in a Nama J2 Juicer: 2 단계, 이미지 3개 중 3개
    • Insert the handle or tool of choice underneath the longer part of the bottom of the auger.
  3. How to Fix a Stuck Auger in a Nama J2 Juicer: 3 단계, 이미지 1개 중 1개
    • Lift up the handle/tool towards you with slight force.
    • The auger should start lift up as you do this.
  4. How to Fix a Stuck Auger in a Nama J2 Juicer: 4 단계, 이미지 1개 중 1개
    • Hold and lift up the auger as you continue to use your tool to remove it.
  5. How to Fix a Stuck Auger in a Nama J2 Juicer: 5 단계, 이미지 1개 중 1개
    • Now that it's loosened, lift up the auger.
  6. How to Fix a Stuck Auger in a Nama J2 Juicer: 6 단계, 이미지 1개 중 1개
    • Congratulations! Now your auger is no longer stuck.
결승점
작성자
1다른 기여자 명과 함께
M. Imperial
회원 가입일: 09/17/24
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 25
전체 시간: 80
