주요 콘텐츠로 건너뛰기
How to Fix a T-shirt That's Too Big
필요한 것
  1. How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: 1 단계, 이미지 1/2 How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: 1 단계, 이미지 2/2
    • Lay the larger T-shirt on a flat surface.
    • Make sure it sits perfectly flat and your side seams are in line.
    • Take another T-shirt that fits you perfectly and lay it on top of the larger T-shirt.
    • Double-check that the neckline is straight and the graphic on the larger T-shirt has plenty of room on either side.
  2. How to Fix a T-shirt That's Too Big: 2 단계, 이미지 1/1
    • Use a water-soluble fabric marker to trace the small T-shirt out on the larger one.
    • Leave some fabric allowance in case you need to fix anything or make adjustments.
  3. How to Fix a T-shirt That's Too Big: 3 단계, 이미지 1/1
    • Use scissors to cut off the excess material.
    • This will divide the shirt into three pieces: the body and two sleeves. Make sure to leave some seam allowance to make adjustments, if needed.
  4. How to Fix a T-shirt That's Too Big: 4 단계, 이미지 1/1
    • Using pins, put the sleeves together in order to give a crease.
    • Pin the rest of the unsewn edges to get a rough idea of whether it is the correct size.
  5. How to Fix a T-shirt That's Too Big: 5 단계, 이미지 1/1
    • Use your sewing machine to sew the parts of the shirt together.
    • Go back over with a smaller stitch to secure the parts of the shirt.
    • This guide uses white thread for visibility. Use a matching thread unless you want contrasting colors. Sew on the inside of the T-shirt to hide your seams.
  6. How to Fix a T-shirt That's Too Big: 6 단계, 이미지 1/1
    • Use scissors to cut any extra threads left over from the project.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
lakshay
회원 가입일: 09/26/22
185 평판
안내서 1개 작성함
York University, Team A-18, Morris Fall 2022 York University, Team A-18, Morris Fall 2022 회원
YORK-MORRIS-F22SAG18
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 51
전체 시간: 1,718
