주요 콘텐츠로 건너뛰기
How to Fix a T-shirt That's Too Big
필요한 것
  1. How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: 1 단계, 이미지 2개 중 1개 How to Fix a T-shirt That's Too Big, How to Fix a T-shirt That's Too Big: 1 단계, 이미지 2개 중 2개
    • Lay the larger T-shirt on a flat surface.
    • Make sure it sits perfectly flat and your side seams are in line.
    • Take another T-shirt that fits you perfectly and lay it on top of the larger T-shirt.
    • Double-check that the neckline is straight and the graphic on the larger T-shirt has plenty of room on either side.
  2. How to Fix a T-shirt That's Too Big: 2 단계, 이미지 1개 중 1개
    • Use a water-soluble fabric marker to trace the small T-shirt out on the larger one.
    • Leave some fabric allowance in case you need to fix anything or make adjustments.
  3. How to Fix a T-shirt That's Too Big: 3 단계, 이미지 1개 중 1개
    • Use scissors to cut off the excess material.
    • This will divide the shirt into three pieces: the body and two sleeves. Make sure to leave some seam allowance to make adjustments, if needed.
  4. How to Fix a T-shirt That's Too Big: 4 단계, 이미지 1개 중 1개
    • Using pins, put the sleeves together in order to give a crease.
    • Pin the rest of the unsewn edges to get a rough idea of whether it is the correct size.
  5. How to Fix a T-shirt That's Too Big: 5 단계, 이미지 1개 중 1개
    • Use your sewing machine to sew the parts of the shirt together.
    • Go back over with a smaller stitch to secure the parts of the shirt.
    • This guide uses white thread for visibility. Use a matching thread unless you want contrasting colors. Sew on the inside of the T-shirt to hide your seams.
  6. How to Fix a T-shirt That's Too Big: 6 단계, 이미지 1개 중 1개
    • Use scissors to cut any extra threads left over from the project.
결승점
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
lakshay
회원 가입일: 09/26/22
203 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 37
전체 시간: 2,432
