주요 콘텐츠로 건너뛰기
How to Fix a Tear in a Jacket Lining
필요한 것
  1. How to Fix a Tear in a Jacket Lining, How to Fix a Tear in a Jacket Lining: 1 단계, 이미지 3개 중 1개 How to Fix a Tear in a Jacket Lining, How to Fix a Tear in a Jacket Lining: 1 단계, 이미지 3개 중 2개 How to Fix a Tear in a Jacket Lining, How to Fix a Tear in a Jacket Lining: 1 단계, 이미지 3개 중 3개
    • Turn the jacket inside out.
  2. How to Fix a Tear in a Jacket Lining: 2 단계, 이미지 2개 중 1개 How to Fix a Tear in a Jacket Lining: 2 단계, 이미지 2개 중 2개
    • Put the thread through the needle hole.
    • Use thread that is the same color as the material you are sewing.
  3. How to Fix a Tear in a Jacket Lining: 3 단계, 이미지 3개 중 1개 How to Fix a Tear in a Jacket Lining: 3 단계, 이미지 3개 중 2개 How to Fix a Tear in a Jacket Lining: 3 단계, 이미지 3개 중 3개
    • Take the two ends of the thread and knot them together.
  4. How to Fix a Tear in a Jacket Lining: 4 단계, 이미지 2개 중 1개 How to Fix a Tear in a Jacket Lining: 4 단계, 이미지 2개 중 2개
    • Cut the excess thread off.
  5. How to Fix a Tear in a Jacket Lining: 5 단계, 이미지 3개 중 1개 How to Fix a Tear in a Jacket Lining: 5 단계, 이미지 3개 중 2개 How to Fix a Tear in a Jacket Lining: 5 단계, 이미지 3개 중 3개
    • Push the needle through the fabric and pull it between the two threads to create a knot.
    • This prevents the thread from sliding through the fabric as you are sewing.
  6. How to Fix a Tear in a Jacket Lining: 6 단계, 이미지 3개 중 1개 How to Fix a Tear in a Jacket Lining: 6 단계, 이미지 3개 중 2개 How to Fix a Tear in a Jacket Lining: 6 단계, 이미지 3개 중 3개
    • Place one stitch on one side then place another one on the other side of the fabric.
    • Make sure the stitches are parallel and evenly distributed or the seams will not look straight.
    • Repeat this process until you have stitched down the length of the tear.
  7. How to Fix a Tear in a Jacket Lining: 7 단계, 이미지 2개 중 1개 How to Fix a Tear in a Jacket Lining: 7 단계, 이미지 2개 중 2개
    • Pull the thread through.
  8. How to Fix a Tear in a Jacket Lining: 8 단계, 이미지 3개 중 1개 How to Fix a Tear in a Jacket Lining: 8 단계, 이미지 3개 중 2개 How to Fix a Tear in a Jacket Lining: 8 단계, 이미지 3개 중 3개
    • Close the stitch.
  9. How to Fix a Tear in a Jacket Lining: 9 단계, 이미지 2개 중 1개 How to Fix a Tear in a Jacket Lining: 9 단계, 이미지 2개 중 2개
    • Cut off the excess thread off after securing the stitch.
  10. How to Fix a Tear in a Jacket Lining: 10 단계, 이미지 2개 중 1개 How to Fix a Tear in a Jacket Lining: 10 단계, 이미지 2개 중 2개
    • This is the final product.
결론
If you mess up on a stitch, you can always cut and pull it out and start all over again.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Electra Pyatt
회원 가입일: 03/22/21
253 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 22
지난 30일: 113
전체 시간: 8,050
