주요 콘텐츠로 건너뛰기
How to Fix a Tear on a Leather Couch
필요한 것
  1. How to Fix a Tear on a Leather Couch, How to Fix a Tear on a Leather Couch: 1 단계, 이미지 1/2 How to Fix a Tear on a Leather Couch, How to Fix a Tear on a Leather Couch: 1 단계, 이미지 2/2
    • Clean the area with small amount of alcohol on a damp washcloth.
  2. How to Fix a Tear on a Leather Couch: 2 단계, 이미지 1/2 How to Fix a Tear on a Leather Couch: 2 단계, 이미지 2/2
    • Measure the length and width of the tear to determine how much subpatch will be needed.
    • Add an extra 1 cm border to each side.
    • Cut the subpatch according to the measurements.
  3. How to Fix a Tear on a Leather Couch: 3 단계, 이미지 1/2 How to Fix a Tear on a Leather Couch: 3 단계, 이미지 2/2
    • Place the sub patch in the hole right behind the tear.
    • Position the sub patch to have 1 cm of excess cloth behind the border of the tear, so the thread can adhere to it.
    • Make a few stitches to secure the patch in place.
  4. How to Fix a Tear on a Leather Couch: 4 단계, 이미지 1/2 How to Fix a Tear on a Leather Couch: 4 단계, 이미지 2/2
    • As an alternative to sewing, you can use vinyl or leather glue to secure the patch in place and close all the flaps of the tears on the surface of the subpatch.
    • Put an even layer of glue behind the border of the tear, adhering it to the patch.
  5. How to Fix a Tear on a Leather Couch: 5 단계, 이미지 1/2 How to Fix a Tear on a Leather Couch: 5 단계, 이미지 2/2
    • Once the patch is stable and dry, use a spatula to apply the leather repair filler in the crevice until you have an even surface.
  6. How to Fix a Tear on a Leather Couch: 6 단계, 이미지 1/2 How to Fix a Tear on a Leather Couch: 6 단계, 이미지 2/2
    • Use sandpaper to smoothen and even out the surface once it's dry.
    • Use the sandpaper to remove any excess filler or wipe it off with alcohol on a damp washcloth.
  7. How to Fix a Tear on a Leather Couch: 7 단계, 이미지 1/2 How to Fix a Tear on a Leather Couch: 7 단계, 이미지 2/2
    • Brush over the heavy filler using a leather paint that matches the color of your sofa.
결승점
Claudia Jimenez
회원 가입일: 10/06/21
175 평판
안내서 1개 작성함
댓글 한 개
Where do you get this product
Carol Lewis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 33
30일 전: 107
전체 시간: 4,561
