주요 콘텐츠로 건너뛰기
How to Fix a Thrustmaster Eswap X Pro Controller Trigger
필요한 것
  1. How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 1 단계, 이미지 1/2 How to Fix a Thrustmaster Eswap X Pro Controller Trigger, How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 1 단계, 이미지 2/2
    • Flip the controller so the backside is facing up.
    • Flip both of the switches away from the center.
  2. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 2 단계, 이미지 1/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 2 단계, 이미지 2/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 2 단계, 이미지 3/3
    • Flip the controller over so the top is facing up.
    • Pull out both the joystick and the directional pad modules.
  3. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 3 단계, 이미지 1/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 3 단계, 이미지 2/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 3 단계, 이미지 3/3
    • Flip the controller over again so the backside is facing up.
    • Use a spudger to remove five rubber screw covers.
  4. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 4 단계, 이미지 1/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 4 단계, 이미지 2/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 4 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove each of the 4.0 mm exposed screws.
  5. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 5 단계, 이미지 1/2 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 5 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to loosen the captive screw and remove the trigger button.
  6. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 6 단계, 이미지 1/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 6 단계, 이미지 2/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 6 단계, 이미지 3/3
    • Rotate the controller 90 degrees.
    • Pull off the magnetic side cover.
  7. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 7 단계, 이미지 1/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 7 단계, 이미지 2/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 7 단계, 이미지 3/3
    • Lift the back cover slightly from where you removed the trigger button.
    • Use a Q-tip dipped with isopropyl alcohol to clean the surrounding area.
    • Additionally, wipe down the top face of the trigger with a Q-tip.
  8. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 8 단계, 이미지 1/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 8 단계, 이미지 2/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 8 단계, 이미지 3/3
    • Reattach the trigger button onto the controller.
    • Use a Phillips #1 screwdriver to tighten the screw securing trigger button.
  9. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 9 단계, 이미지 1/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 9 단계, 이미지 2/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 9 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to reattach the 4.0 mm screws to the back of the controller.
  10. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 10 단계, 이미지 1/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 10 단계, 이미지 2/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 10 단계, 이미지 3/3
    • Notice that the notches on the rubber covers correspond with the notches on the screw hole.
    • Reattach the rubber covers above the screws.
  11. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 11 단계, 이미지 1/1
    • Place the joystick and the directional pad modules back in their respective spots.
  12. How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 12 단계, 이미지 1/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 12 단계, 이미지 2/3 How to Fix a Thrustmaster Eswap X Pro Controller Trigger: 12 단계, 이미지 3/3
    • Reattach the magnetic side cover.
    • The controller is fixed!
결론
Laurence Chan
회원 가입일: 01/26/23
205 평판
안내서 1개 작성함
UC Davis, Team 2-3, Morris Winter 2023 UC Davis, Team 2-3, Morris Winter 2023 회원
UCD-MORRIS-W23S2G3
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 42
30일 전: 144
전체 시간: 2,073
