주요 콘텐츠로 건너뛰기
How to Fix a Torn Slipper
필요한 것
  1. How to Fix a Torn Slipper, Glue up the vamp of the shoe: 1 단계, 이미지 2개 중 1개 How to Fix a Torn Slipper, Glue up the vamp of the shoe: 1 단계, 이미지 2개 중 2개
    • Use glue to glue up the torn part of the vamp (the top part of the shoe)
    • This is done to make it easier for the later stage. if the vamp wasn't broken, this step can be skipped.
  2. How to Fix a Torn Slipper, Measure the cloth you need: 2 단계, 이미지 3개 중 1개 How to Fix a Torn Slipper, Measure the cloth you need: 2 단계, 이미지 3개 중 2개 How to Fix a Torn Slipper, Measure the cloth you need: 2 단계, 이미지 3개 중 3개
    • Grab a piece of cloth and measure the amount needed to fix your shoe and cut it out.
  3. How to Fix a Torn Slipper, Glue the cloth to the shoe: 3 단계, 이미지 3개 중 1개 How to Fix a Torn Slipper, Glue the cloth to the shoe: 3 단계, 이미지 3개 중 2개 How to Fix a Torn Slipper, Glue the cloth to the shoe: 3 단계, 이미지 3개 중 3개
    • Glue the piece of cloth onto the shoe.
    • This step isn't needed if you are a pro, glue was used for holding the shoe and the cloth for easy sewing.
  4. How to Fix a Torn Slipper, Sewing the cloth to the shoe: 4 단계, 이미지 3개 중 1개 How to Fix a Torn Slipper, Sewing the cloth to the shoe: 4 단계, 이미지 3개 중 2개 How to Fix a Torn Slipper, Sewing the cloth to the shoe: 4 단계, 이미지 3개 중 3개
    • Now poke your thread over your needle
    • After you poke your thread into the needle, start sewing back and front, sew all the way around the cloth.
    • Be careful not to poke your hand while you are sewing
  5. How to Fix a Torn Slipper, Glue fixed vamp to the bottom of the shoe: 5 단계, 이미지 2개 중 1개 How to Fix a Torn Slipper, Glue fixed vamp to the bottom of the shoe: 5 단계, 이미지 2개 중 2개
    • Use glue to hold the vamp and the bottom of the shoe together.
    • This is similar to step 3, if you are a pro with sewing you can skip this step.
  6. How to Fix a Torn Slipper, Sew the bottom and the vamp together.: 6 단계, 이미지 3개 중 1개 How to Fix a Torn Slipper, Sew the bottom and the vamp together.: 6 단계, 이미지 3개 중 2개 How to Fix a Torn Slipper, Sew the bottom and the vamp together.: 6 단계, 이미지 3개 중 3개
    • Now sew the top and bottom of the shoe together. Poke in from the side and down the bottom again and again.
    • If it is hard to poke through, you can always use something hard to help with pushing the needle through.
  7. How to Fix a Torn Slipper, The end: 7 단계, 이미지 2개 중 1개 How to Fix a Torn Slipper, The end: 7 단계, 이미지 2개 중 2개
    • Now, this is ready for use.
    • You can always use a thread and cloth that fit the colour of your shoe to look nice.
결론
This isn’t a very hard guide and can be performed by anyone who has enough time and tools to complete it.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
jia liu
회원 가입일: 09/19/21
171 평판
안내서 1개를 작성함
York University, Team F-16, Woodhouse Fall 2021 York University, Team F-16, Woodhouse Fall 2021 회원
YORK-WOODHOUSE-F21SFG16
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 72
전체 시간: 2,670
