주요 콘텐츠로 건너뛰기
How to Fix a Whirlpool WDF330PAHW Door Latch
필요한 것
  1. How to Fix a Whirlpool WDF330PAHW Door Latch, How to Fix a Whirlpool WDF330PAHW Door Latch: 1 단계, 이미지 2개 중 1개 How to Fix a Whirlpool WDF330PAHW Door Latch, How to Fix a Whirlpool WDF330PAHW Door Latch: 1 단계, 이미지 2개 중 2개
    • Open the dishwasher door and look for the retaining screws around the side edge and top edge of the dishwasher door.
  2. How to Fix a Whirlpool WDF330PAHW Door Latch: 2 단계, 이미지 1개 중 1개
    • Using a T8 Torx screwdriver remove the two screws by turning counter clockwise.
  3. How to Fix a Whirlpool WDF330PAHW Door Latch: 3 단계, 이미지 2개 중 1개 How to Fix a Whirlpool WDF330PAHW Door Latch: 3 단계, 이미지 2개 중 2개
    • Lift the inner panel enough that you can loosen the two securing bolts on the door latch with the wrench.
    • When loosening the two bolts, leave them in and don't remove them.
  4. How to Fix a Whirlpool WDF330PAHW Door Latch: 4 단계, 이미지 2개 중 1개 How to Fix a Whirlpool WDF330PAHW Door Latch: 4 단계, 이미지 2개 중 2개
    • Carefully raise the dishwasher door to align the door latch with the strike plate.
    • Watch fingers while raising dishwasher door.
  5. How to Fix a Whirlpool WDF330PAHW Door Latch: 5 단계, 이미지 1개 중 1개
    • Hold the door latch with your finger tips to align the door latch.
    • Then lower the door and tighten the door latch securing bolts.
  6. How to Fix a Whirlpool WDF330PAHW Door Latch: 6 단계, 이미지 1개 중 1개
    • Install the inner door panel retaining screws.
    • Proceed to tighten two screws with the T8 Torx screwdriver.
    • When tightening the two screws turn clockwise.
    • Then close the dishwasher door.
결승점
작성자
3다른 기여자 명과 함께
Magdalene Cannon
회원 가입일: 04/13/20
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 17
지난 30일: 70
전체 시간: 4,174
