소개
If you notice that the print bed on your Creality Ender-3 Pro 3D printer is wobbling, the wheel bearings under the print bed that align with the y-axis have probably come loose from the railing holding them in place.
The printer uses very thin layers of filament, so any sort of movement outside of the precise instructions given to it will result in failed prints until a fix is made. This guide will illustrate how to turn the eccentric nut connected to the loose wheel bearing in order to secure the wheel bearing to its railing.
Before beginning this repair, disconnect the printer from its power source and make sure the print bed is cooled to room temperature.
필요한 것
Unscrew the leveling wheels under the bed and remove the print bed from its brackets.
Your y-axis should now be secured without the worry of misprinted layers. Happy printing!
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
Just want to say this is by far the most helpful of all how to articles I saw to address this issue. Thank you
