주요 콘텐츠로 건너뛰기
How to Fix a Wobbly Chair
필요한 것
  1. How to Fix a Wobbly Chair, How to Fix a Wobbly Chair: 1 단계, 이미지 1/3 How to Fix a Wobbly Chair, How to Fix a Wobbly Chair: 1 단계, 이미지 2/3 How to Fix a Wobbly Chair, How to Fix a Wobbly Chair: 1 단계, 이미지 3/3
    • Flip the chair upside down.
    • Put the chair on your lap or on the table.
  2. How to Fix a Wobbly Chair: 2 단계, 이미지 1/3 How to Fix a Wobbly Chair: 2 단계, 이미지 2/3 How to Fix a Wobbly Chair: 2 단계, 이미지 3/3
    • Clean and disinfect the screws.
  3. How to Fix a Wobbly Chair: 3 단계, 이미지 1/3 How to Fix a Wobbly Chair: 3 단계, 이미지 2/3 How to Fix a Wobbly Chair: 3 단계, 이미지 3/3
    • Use a power drill with a hex bit to remove the screws.
  4. How to Fix a Wobbly Chair: 4 단계, 이미지 1/2 How to Fix a Wobbly Chair: 4 단계, 이미지 2/2
    • Clean the holes with a cloth or a cotton swab dipped in disinfectant.
  5. How to Fix a Wobbly Chair: 5 단계, 이미지 1/3 How to Fix a Wobbly Chair: 5 단계, 이미지 2/3 How to Fix a Wobbly Chair: 5 단계, 이미지 3/3
    • Reinsert the new screws and washers.
    • Tightly secure the screws.
  6. How to Fix a Wobbly Chair: 6 단계, 이미지 1/2 How to Fix a Wobbly Chair: 6 단계, 이미지 2/2
    • Check to see if the chair is still loose.
    • If the chair doesn't wobble, then you are finished.
결승점
Kevin Briones
회원 가입일: 04/01/21
133 평판
안내서 1개 작성함
CSU Los Angeles, Team S1-G1, Harris Spring 2021 CSU Los Angeles, Team S1-G1, Harris Spring 2021 회원
CSULA-HARRIS-S21S1G1
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 19
전체 시간: 301
