주요 콘텐츠로 건너뛰기
How to Fix a Wobbly Hydraulic Barber Chair
필요한 것
  1. How to Fix a Wobbly Hydraulic Barber Chair, How to Fix a Wobbly Hydraulic Barber Chair: 1 단계, 이미지 1/2 How to Fix a Wobbly Hydraulic Barber Chair, How to Fix a Wobbly Hydraulic Barber Chair: 1 단계, 이미지 2/2
    • The issue with the barber chair is located at the base, where the screws have come loose.
  2. How to Fix a Wobbly Hydraulic Barber Chair: 2 단계, 이미지 1/2 How to Fix a Wobbly Hydraulic Barber Chair: 2 단계, 이미지 2/2
    • Use your foot to repeatedly pump the hydraulic height-adjustment pedal under the chair until the chair reaches max height.
    • While holding the pedal down with your foot, grab both arm rests and pull the chair upwards.
  3. How to Fix a Wobbly Hydraulic Barber Chair: 3 단계, 이미지 1/1
    • Lift the base-ring off the base to reveal the holes for the screws.
  4. How to Fix a Wobbly Hydraulic Barber Chair: 4 단계, 이미지 1/1
    • Place a screw with a washer attached into a hole and tighten it with a 7/32" hex bit.
    • Repeat this process for the other 5 screws and washers.
  5. How to Fix a Wobbly Hydraulic Barber Chair: 5 단계, 이미지 1/1
    • Align the bottom of the seat with the top of the pole, and gently put it back into position.
  6. How to Fix a Wobbly Hydraulic Barber Chair: 6 단계, 이미지 1/1
    • Make sure the seat is properly fitted onto the pole by gently pushing down on the seat.
    • Check the stability of the pole by gently shaking the chair.
결론
Gaurav Tiwari
회원 가입일: 01/21/21
133 평판
안내서 1개 작성함
York University, Team S1-G28, Melo-Thaiss Winter 2021 York University, Team S1-G28, Melo-Thaiss Winter 2021 회원
YORK-MELO-THAISS-W21S1G28
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 22
30일 전: 71
전체 시간: 3,563
