주요 콘텐츠로 건너뛰기
How to Fix a Wobbly Hydraulic Barber Chair
필요한 것
  1. How to Fix a Wobbly Hydraulic Barber Chair, How to Fix a Wobbly Hydraulic Barber Chair: 1 단계, 이미지 2개 중 1개 How to Fix a Wobbly Hydraulic Barber Chair, How to Fix a Wobbly Hydraulic Barber Chair: 1 단계, 이미지 2개 중 2개
    • The issue with the barber chair is located at the base, where the screws have come loose.
  2. How to Fix a Wobbly Hydraulic Barber Chair: 2 단계, 이미지 2개 중 1개 How to Fix a Wobbly Hydraulic Barber Chair: 2 단계, 이미지 2개 중 2개
    • Use your foot to repeatedly pump the hydraulic height-adjustment pedal under the chair until the chair reaches max height.
    • While holding the pedal down with your foot, grab both arm rests and pull the chair upwards.
  3. How to Fix a Wobbly Hydraulic Barber Chair: 3 단계, 이미지 1개 중 1개
    • Lift the base-ring off the base to reveal the holes for the screws.
  4. How to Fix a Wobbly Hydraulic Barber Chair: 4 단계, 이미지 1개 중 1개
    • Place a screw with a washer attached into a hole and tighten it with a 7/32" hex bit.
    • Repeat this process for the other 5 screws and washers.
  5. How to Fix a Wobbly Hydraulic Barber Chair: 5 단계, 이미지 1개 중 1개
    • Align the bottom of the seat with the top of the pole, and gently put it back into position.
  6. How to Fix a Wobbly Hydraulic Barber Chair: 6 단계, 이미지 1개 중 1개
    • Make sure the seat is properly fitted onto the pole by gently pushing down on the seat.
    • Check the stability of the pole by gently shaking the chair.
결론
작성자
2다른 기여자 명과 함께
Gaurav Tiwari
회원 가입일: 01/21/21
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 47
전체 시간: 5,210
