주요 콘텐츠로 건너뛰기
How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest
필요한 것
  1. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest, How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: 1 단계, 이미지 1/2 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest, How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: 1 단계, 이미지 2/2
    • Lean back the chair and extend the leg rest completely.
  2. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: 2 단계, 이미지 1/1
    • Lay the chair on its side on the ground to allow easier access to the required hex screws and blocker screw.
  3. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: 3 단계, 이미지 1/3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: 3 단계, 이미지 2/3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: 3 단계, 이미지 3/3
    • Remove the 3 mm blocker screw using a 3mm Allen wrench/hex key.
  4. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: 4 단계, 이미지 1/1
    • Slide the leg rest out of the base.
  5. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: 5 단계, 이미지 1/2 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: 5 단계, 이미지 2/2
    • Place the leg rest on a flat surface.
    • Wipe clean the sliding legs using a clean cloth to ensure the sliding mechanism has no issues.
  6. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: 6 단계, 이미지 1/3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: 6 단계, 이미지 2/3 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: 6 단계, 이미지 3/3
    • Tighten the four 25 mm hex screws located at the bottom of the chair using the 3 mm Allen key.
    • Be careful not to over tighten the 25 mm hex screws. This can cause the screw to become free from the base.
  7. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: 7 단계, 이미지 1/1
    • Slide the leg rest back into the base.
  8. How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: 8 단계, 이미지 1/2 How to Fix a Wobbly Wolf Warriors Gaming Chair Leg Rest: 8 단계, 이미지 2/2
    • Screw the 3 mm blocker screw back in.
    • Flip your chair back up and enjoy your sturdy leg rest!
결론
Anoop Shahi
회원 가입일: 01/17/21
157 평판
안내서 1개 작성함
York University, Team S1-G26, O'Regan Winter 2021 York University, Team S1-G26, O'Regan Winter 2021 회원
YORK-O'REGAN-W21S1G26
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 441
