주요 콘텐츠로 건너뛰기
How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller
필요한 것
  1. How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller, How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 1 단계, 이미지 1/2 How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller, How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 1 단계, 이미지 2/2
    • Place a prying tool in the crease of the right side of the controller.
    • Slide the prying tool until the controller begins to pop open.
  2. How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 2 단계, 이미지 1/1
    • Insert an opening pick into the space to keep the controller from snapping shut.
  3. How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 3 단계, 이미지 1/3 How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 3 단계, 이미지 2/3 How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 3 단계, 이미지 3/3
    • Continue to use the prying tool down the side of the controller.
    • The bottom right handle will pop open.
  4. How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 4 단계, 이미지 1/1
    • Slide the prying tool along the crease of the bottom of the controller.
  5. How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 5 단계, 이미지 1/2 How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 5 단계, 이미지 2/2
    • Place the prying tool in the crease of the left side of the controller.
  6. How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 6 단계, 이미지 1/1
  7. How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 7 단계, 이미지 1/2 How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 7 단계, 이미지 2/2
    • Continue to slide the prying tool in the crease of the controller.
    • The bottom handle will pop open.
  8. How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 8 단계, 이미지 1/3 How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 8 단계, 이미지 2/3 How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 8 단계, 이미지 3/3
    • Place the prying tool into the space at the top of the controller.
    • Slide the prying tool until the entire top half of the controller is loose.
  9. How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 9 단계, 이미지 1/1
    • Remove the top half of the controller.
  10. How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 10 단계, 이미지 1/2 How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 10 단계, 이미지 2/2
    • Twist the analog stick counterclockwise until it comes off.
  11. How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 11 단계, 이미지 1/2 How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 11 단계, 이미지 2/2
    • Use a spudger to open the sensor.
  12. How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 12 단계, 이미지 1/1
    • Place the tip of the straw from the can of compressed air into space near the sensor.
    • Spray the can of compressed air until the sensor is free of debris.
    • Do not get the liquid from the can of compressed air into the sensor or anywhere in the controller.
  13. How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 13 단계, 이미지 1/2 How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 13 단계, 이미지 2/2
    • Use a spudger to close the sensor.
  14. How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 14 단계, 이미지 1/1
    • Replace the analog stick, and twist to the right until it tightens.
  15. How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 15 단계, 이미지 1/3 How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 15 단계, 이미지 2/3 How to Fix an Analog Stick Drift in an Xbox One Elite Series 2 Controller: 15 단계, 이미지 3/3
    • Place the top half of the controller back onto the bottom half.
    • Push on the bottom, top, and sides until they snap together.
결승점
다른 26명이 해당 안내서를 완성하였습니다.
Aliyah Castaneda
회원 가입일: 11/17/21
988 평판
안내서 1개 작성함
Idaho State University, Team 1-4, Watkins Fall 2021 Idaho State University, Team 1-4, Watkins Fall 2021 회원
ISU-WATKINS-F21S1G4
1 회원
안내서 8개 작성하였습니다
댓글 15개
very good guide way easier to follow then others i’ve seen :) Thanks
munch483 - 답글
Maybe im just too scared to totally ruin/ rip/ snap or otherwise DESTROY this thing or stab myself with a pry tool but it seems like this is WAY harder then the pictures/guide make it out to be. The top face plate is FAR FAR FAR harder to release then the guide says.. Its not like a regular controller AT ALL.. I have cut myself to the point of blood now with the sheer effort of trying to push a pry tool between the seam EXATLY where the picture shows.. It did NOT help at all.
Napster6 - 답글
Hey Napster, You are very right. I bought this controller preowned and there are slice marks in the rubber where the person tried to open it and failed. I was able to open with out a terrible amount of difficulty by using the thin metal wedger tool thingy from the ifixit kit while simultaneously holding portions open with the blue triangle. Try pushing the tip of whatever your using to the bottom half of the controller then in a little more and then pry up. (near the b button). If it pops the top half out a little then wedge a placeholder in there then try the other side. Once you get both sides try a little lower near the vibrator then same for the other side and by then it should be easy enough to open with your hands. I struggled heavily the first time but found this was the easiest way. Good luck!
Jake H -
This is such an awesome guide! Fixed my controller drift and a saved me a ton of money in the long run. Thanks so much!
Lord Meowmers - 답글
I had issues with numerous parts of this guide.
As others mentioned, opening the case is quite difficult. I found that using the metal Jimmy tool included in the Essential Electronics Toolkit helped to loosen up the right-side seam enough so that the middle of the right-side seam was where I was first able to insert a pick. Once I was finally able to get the whole thing open, I noticed there was a small amount of adhesive which the Jimmy may have helped to slice apart.
I was not able to remove the joystick at all despite being able to rotate it as instructed. I found that I was able to access the sensor for cleaning as described without removing the stick at all. But, on that note, the spudger included in the Essential Electronics Toolkit was too large to open the sensor gap. The smallest flathead bit included in the kit fit perfectly. FWIW, the spudger pictured is not the same one included in the toolkit…
cdom - 답글
댓글 쓰기
조회 통계:
24 시간 전: 229
7일 전: 1,812
30일 전: 8,554
전체 시간: 119,071
