주요 콘텐츠로 건너뛰기
How to Fix an Armhole Gape
필요한 것
  1. How to Fix an Armhole Gape, How to Fix an Armhole Gape: 1 단계, 이미지 1개 중 1개
    • Gather the supplies needed.
  2. How to Fix an Armhole Gape: 2 단계, 이미지 2개 중 1개 How to Fix an Armhole Gape: 2 단계, 이미지 2개 중 2개
    • Grab your measuring tape.
    • Measure from the middle of the breast to the under arm part.
  3. How to Fix an Armhole Gape: 3 단계, 이미지 3개 중 1개 How to Fix an Armhole Gape: 3 단계, 이미지 3개 중 2개 How to Fix an Armhole Gape: 3 단계, 이미지 3개 중 3개
    • Mark the middle of the breast and at the end where the under arm is. (Slide one and two)
    • Mark how big you want to close the gape. (Depends on how big your armhole gape is) (Slide three)
    • Mine was about 0.5 inches. (Slide three)
  4. How to Fix an Armhole Gape: 4 단계, 이미지 3개 중 1개 How to Fix an Armhole Gape: 4 단계, 이미지 3개 중 2개 How to Fix an Armhole Gape: 4 단계, 이미지 3개 중 3개
    • Connect both of the dots from the breast to the two dots you marked near the underarm.
    • Fold the second line you created and pin them to keep it coming from getting undone. (Slides two and three)
  5. How to Fix an Armhole Gape: 5 단계, 이미지 1개 중 1개
    • Sew across.
    • I used a straight sew stitch by hand (you can use a sewing machine and any stitch)
  6. How to Fix an Armhole Gape: 6 단계, 이미지 1개 중 1개
    • Lastly, cut the access off.
    • Then flip it inside out.
    • And your done!
결론
Thank you for taking the time to read this.
작성자
2다른 기여자 명과 함께
Danielle Fontanos
회원 가입일: 10/23/23
133 평판
안내서 1개를 작성함
CSU Los Angeles, Team 5-6, Kershman Fall 2023 CSU Los Angeles, Team 5-6, Kershman Fall 2023 회원
CSULA-KERSHMAN-F23S5G6
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 25
전체 시간: 329
