주요 콘텐츠로 건너뛰기
How to Fix an OXO Container's Jammed Button
필요한 것
  1. How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: 1 단계, 이미지 3개 중 1개 How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: 1 단계, 이미지 3개 중 2개 How to Fix an OXO Container's Jammed Button, How to Fix an OXO Container's Jammed Button: 1 단계, 이미지 3개 중 3개
    • Hold the lid with the button facing down.
    • Twist the flat part in the direction of the arrows or counter clockwise.
  2. How to Fix an OXO Container's Jammed Button: 2 단계, 이미지 3개 중 1개 How to Fix an OXO Container's Jammed Button: 2 단계, 이미지 3개 중 2개 How to Fix an OXO Container's Jammed Button: 2 단계, 이미지 3개 중 3개
    • Firmly pinch both the half-moon shaped openings.
    • Pull up the removed outer piece and set it aside.
  3. How to Fix an OXO Container's Jammed Button: 3 단계, 이미지 1개 중 1개
    • Place the lid perpendicular and onto the top of the container's opening.
    • The button should pop out. Placing the lid on a flat surface will prevent them from coming out.
    • Locate the two holes.
  4. How to Fix an OXO Container's Jammed Button: 4 단계, 이미지 2개 중 1개 How to Fix an OXO Container's Jammed Button: 4 단계, 이미지 2개 중 2개
    • With a tool in each hand, insert them into the openings of the buttons.
    • Make sure the two tools are centered on the plastic in the openings.
    • Tools must be small enough to fit inside the openings - alternatives to spudgers work.
    • Firmly press downwards until the button pops out.
    • Applying a lot of pressure is necessary, but also may damage the plastic of the lid.
  5. How to Fix an OXO Container's Jammed Button: 5 단계, 이미지 2개 중 1개 How to Fix an OXO Container's Jammed Button: 5 단계, 이미지 2개 중 2개
    • Flip the lid so the button faces up.
    • It should be easy to pinch the sides of the button so that it pops up.
    • Pinch the two sides and gently pull up.
    • Remove the button.
  6. How to Fix an OXO Container's Jammed Button: 6 단계, 이미지 3개 중 1개 How to Fix an OXO Container's Jammed Button: 6 단계, 이미지 3개 중 2개 How to Fix an OXO Container's Jammed Button: 6 단계, 이미지 3개 중 3개
    • Flip the button so the inside wire faces upwards.
    • Use pliers to bend the wire similar to its original shape.
    • Use the unbent wire as a reference to reshape the bent wire.
결론
To reassemble your device, squeeze the button back onto the lid and follow these instructions in reverse order.
작성자
4다른 기여자 명과 함께
Allen Wong
회원 가입일: 02/03/23
133 평판
안내서 1개를 작성함
UC Davis, Team 2-5, Andersen Winter 2023 UC Davis, Team 2-5, Andersen Winter 2023 회원
UCD-ANDERSEN-W23S2G5
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 26
지난 30일: 118
전체 시간: 6,149
