주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Fix an Overextending Holga 120N Camera Shutter
필요한 것
  1. How to Fix an Overextending Holga 120N Camera Shutter, How to Fix an Overextending Holga 120N Camera Shutter: 1 단계, 이미지 2개 중 1개 How to Fix an Overextending Holga 120N Camera Shutter, How to Fix an Overextending Holga 120N Camera Shutter: 1 단계, 이미지 2개 중 2개
    • Slide the two metal lanyard locks up and off the camera.
    • Pop the back of the camera off.
    댓글 쓰기
  2. How to Fix an Overextending Holga 120N Camera Shutter: 2 단계, 이미지 2개 중 1개 How to Fix an Overextending Holga 120N Camera Shutter: 2 단계, 이미지 2개 중 2개
    • Remove the screw above the opening to the shutter piece using a Phillips #00 screwdriver.
    • Remove the screw below the opening to the shutter piece using a Phillips #00 screwdriver.
    댓글 쓰기
  3. How to Fix an Overextending Holga 120N Camera Shutter: 3 단계, 이미지 1개 중 1개
    • Pull the shutter piece out and away from the camera.
    • Pull the shutter piece away carefully to avoid snapping the wire.
    댓글 쓰기
  4. How to Fix an Overextending Holga 120N Camera Shutter: 4 단계, 이미지 3개 중 1개 How to Fix an Overextending Holga 120N Camera Shutter: 4 단계, 이미지 3개 중 2개 How to Fix an Overextending Holga 120N Camera Shutter: 4 단계, 이미지 3개 중 3개
    • Cut off the spade terminal's right prong with scissors.
    댓글 쓰기
  5. How to Fix an Overextending Holga 120N Camera Shutter: 5 단계, 이미지 1개 중 1개
    • Bend the spade terminal forward at a 90-degree angle.
    댓글 쓰기
  6. How to Fix an Overextending Holga 120N Camera Shutter: 6 단계, 이미지 2개 중 1개 How to Fix an Overextending Holga 120N Camera Shutter: 6 단계, 이미지 2개 중 2개
    • Slice the blue plastic off of the spade terminal with the boxcutter/Exacto-knife.
    • The plastic bottom is sealed on very tightly. Use caution when cutting it away!
    • Remove the plastic from the spade terminal.
    댓글 쓰기
  7. How to Fix an Overextending Holga 120N Camera Shutter: 7 단계, 이미지 3개 중 1개 How to Fix an Overextending Holga 120N Camera Shutter: 7 단계, 이미지 3개 중 2개 How to Fix an Overextending Holga 120N Camera Shutter: 7 단계, 이미지 3개 중 3개
    • Place hot glue at the bottom of the spade terminal.
    • Place the spade terminal in the small hole underneath the shutter.
    • Point the spade terminal horizontally, facing the wire that leads back to the camera.
    댓글 쓰기
  8. How to Fix an Overextending Holga 120N Camera Shutter: 8 단계, 이미지 1개 중 1개
    • Screw the shutter piece back into place using a Phillips #00 screwdriver.
    댓글 쓰기
  9. How to Fix an Overextending Holga 120N Camera Shutter: 9 단계, 이미지 2개 중 1개 How to Fix an Overextending Holga 120N Camera Shutter: 9 단계, 이미지 2개 중 2개
    • Return the back of the camera into place.
    댓글 쓰기
결론
You’ve now learned the following:
  • How to disassemble and reassemble a Holga 120N camera
  • How to add a spade terminal as a blocker
The spade terminal will stop the overextended shutter. Enjoy taking pictures!
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jacob DeLany
회원 가입일: 09/28/21
196 평판
안내서 1개를 작성함
1가이드 댓글
That's a PZ1 bit which gets the screws out easily. If you got the screws out with a PH00 bit, either they changed the way the camera is made before mine was made or you are quite tenacious in your screwdriving.
s l - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 75
전체 시간: 2,962
