주요 콘텐츠로 건너뛰기
How to Fix an Umbrella Rivet
필요한 것
  1. How to Fix an Umbrella Rivet, How to Fix an Umbrella Rivet: 1 단계, 이미지 1개 중 1개
    • Open the umbrella into its proper position.
  2. How to Fix an Umbrella Rivet: 2 단계, 이미지 1개 중 1개
    • Identify the broken stretcher that needs to be repaired.
  3. How to Fix an Umbrella Rivet: 3 단계, 이미지 1개 중 1개
    • Close the umbrella halfway to release the tension in the stretchers.
    • This makes it easier to line up the holes in the next step.
  4. How to Fix an Umbrella Rivet: 4 단계, 이미지 1개 중 1개
    • Take the two pieces of the broken stretcher and line up the rivet holes.
  5. How to Fix an Umbrella Rivet: 5 단계, 이미지 1개 중 1개
    • Pass the 6" piece of wire through the rivet holes.
  6. How to Fix an Umbrella Rivet: 6 단계, 이미지 1개 중 1개
    • Wrap the wire around the stretcher and thread it through the holes again.
    • Repeat until there is no more room to pass the wire through.
    • May need to use the pliers to get a better grip on the wire so it can be pulled tight.
  7. How to Fix an Umbrella Rivet: 7 단계, 이미지 1개 중 1개
    • Tie two half-hitch knots with the wire.
    • If you do not know how to tie a half-hitch knot, follow the link provided at the beginning of the guide.
  8. How to Fix an Umbrella Rivet: 8 단계, 이미지 1개 중 1개
    • Use the scissors to trim the two ends of the wire to about half an inch in length.
  9. How to Fix an Umbrella Rivet: 9 단계, 이미지 1개 중 1개
    • Using the pliers, twist the ends of the wire together.
  10. How to Fix an Umbrella Rivet: 10 단계, 이미지 1개 중 1개
    • Tuck the wires down and clamp with the pliers so the ends are not poking out.
결승점
다른 8명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Alexandra Hamelin
회원 가입일: 06/08/16
312 평판
안내서 1개를 작성함
Texas Tech, Team 3-8, Rauch SU 2016 Texas Tech, Team 3-8, Rauch SU 2016 회원
TTU-RAUCH-SU16S3G8
2 회원들
안내서 5개를 작성함
7가이드 댓글
This is not called an ‘umbrella rivet replacement’.
SouthPark - 답글
I fixed my umbrella! Thank you. Umbrella is very old though, will see how much more time I can buy with this fix :)
Lou - 답글
The fix lasted about a month and a half and then the copper wire broke. I am trying the same technique but this time with a metal paper clip that I had. The paper clip is made of metal that's thicker than the copper wire. I only threaded it through one time and then twisted the ends. One paper clip was enough to fix 2 rivets (both the original one and a new one is now broken as well). I will try to report back if these also break.
Lou - 답글
6 months later and paperclip fix is still holding!
Lou -
Thanks! A paperclip worked!
Mayra L. -
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 86
지난 30일: 382
전체 시간: 31,260
