주요 콘텐츠로 건너뛰기
How to Fix an Uneven Guitar Fret
필요한 것
  1. How to Fix an Uneven Guitar Fret, How to Fix an Uneven Guitar Fret: 1 단계, 이미지 2개 중 1개 How to Fix an Uneven Guitar Fret, How to Fix an Uneven Guitar Fret: 1 단계, 이미지 2개 중 2개
    • Loosen the strings by turning each knob on the left of the guitar counter-clockwise.
    • Loosen until you can fit one finger underneath.
  2. How to Fix an Uneven Guitar Fret: 2 단계, 이미지 1개 중 1개
    • Locate the general area where the strings are buzzing due to the uneven fret.
    • Place the long side of the fret rocker down over three frets.
    • Rock the fret rocker side to side.
    • If it moves, the fret in the middle of the three is higher than the others.
  3. How to Fix an Uneven Guitar Fret: 3 단계, 이미지 1개 중 1개
    • Place the fret guard underneath the strings and over the uneven fret.
  4. How to Fix an Uneven Guitar Fret: 4 단계, 이미지 3개 중 1개 How to Fix an Uneven Guitar Fret: 4 단계, 이미지 3개 중 2개 How to Fix an Uneven Guitar Fret: 4 단계, 이미지 3개 중 3개
    • Take one paper towel sheet and fold in half the long way.
    • Roll the paper towel tightly about halfway down the sheet.
    • Cut the paper towel as pictured.
    • Repeat once more, you should have two small paper towel rolls.
  5. How to Fix an Uneven Guitar Fret: 5 단계, 이미지 1개 중 1개
    • Place the two rolls under the strings around the fret guard.
  6. How to Fix an Uneven Guitar Fret: 6 단계, 이미지 2개 중 1개 How to Fix an Uneven Guitar Fret: 6 단계, 이미지 2개 중 2개
    • File the top of the fret in an up down motion
    • Start slow, file back and forth only a couple times then see step 7
  7. How to Fix an Uneven Guitar Fret: 7 단계, 이미지 1개 중 1개
    • Place the fret rocker over the frets again.
    • If it still rocks, repeat the previous step.
  8. How to Fix an Uneven Guitar Fret: 8 단계, 이미지 3개 중 1개 How to Fix an Uneven Guitar Fret: 8 단계, 이미지 3개 중 2개 How to Fix an Uneven Guitar Fret: 8 단계, 이미지 3개 중 3개
    • Polish the top of the frets by sandpapering the top of the fret in an up/down motion.
    • Stop when fret feels smooth and looks shiny.
결론
작성자
3다른 기여자 명과 함께
Victoria
회원 가입일: 04/25/24
157 평판
안내서 1개를 작성함
UC Davis, Team 1-1, Whithaus Spring 2024 UC Davis, Team 1-1, Whithaus Spring 2024 회원
UCD-WHITHAUS-S24S1G1
3 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 11
전체 시간: 345
