주요 콘텐츠로 건너뛰기
How to Fix an Unleveled Sofa Seat
필요한 것
  1. How to Fix an Unleveled Sofa Seat, How to Fix an Unleveled Sofa Seat: 1 단계, 이미지 2개 중 1개 How to Fix an Unleveled Sofa Seat, How to Fix an Unleveled Sofa Seat: 1 단계, 이미지 2개 중 2개
    • First get one or two partners depending on how big the sofa is to flip the sofa upside down with you.
  2. How to Fix an Unleveled Sofa Seat: 2 단계, 이미지 3개 중 1개 How to Fix an Unleveled Sofa Seat: 2 단계, 이미지 3개 중 2개 How to Fix an Unleveled Sofa Seat: 2 단계, 이미지 3개 중 3개
    • To find the exact problem of making the sofa seat unleveled, use a utility knife to cut a line across the corners of the big sheet covering the wood in the sofa.
    • Remove the big sheet covering the wood in the sofa seats to expose the problem, as the wood is what holds the sofa together.
  3. How to Fix an Unleveled Sofa Seat: 3 단계, 이미지 1개 중 1개
    • Find the unleveled wood in the sofa seat which was the cause of the unleveled sofa seat.
  4. How to Fix an Unleveled Sofa Seat: 4 단계, 이미지 3개 중 1개 How to Fix an Unleveled Sofa Seat: 4 단계, 이미지 3개 중 2개 How to Fix an Unleveled Sofa Seat: 4 단계, 이미지 3개 중 3개
    • Using a hammer, put a piece of wood on top of the unleveled wood, allowing you to have a larger surface to hammer on as you try to align the unlevelled wood back into its position.
  5. How to Fix an Unleveled Sofa Seat: 5 단계, 이미지 1개 중 1개
    • Take measurements for a piece of wood that spans the break, reaching both the recently unleveled wood and the already sturdy wood in the sofa.
  6. How to Fix an Unleveled Sofa Seat: 6 단계, 이미지 3개 중 1개 How to Fix an Unleveled Sofa Seat: 6 단계, 이미지 3개 중 2개 How to Fix an Unleveled Sofa Seat: 6 단계, 이미지 3개 중 3개
    • Glue up one side of the piece of wood that was just cut out.
    • Place that wood firmly on a surface that reaches the wood that was recently unleveled and also in the same line a piece of wood that was already sturdy in the sofa.
  7. How to Fix an Unleveled Sofa Seat: 7 단계, 이미지 3개 중 1개 How to Fix an Unleveled Sofa Seat: 7 단계, 이미지 3개 중 2개 How to Fix an Unleveled Sofa Seat: 7 단계, 이미지 3개 중 3개
    • Take one screw and screw it into where where it goes through the new piece of wood first, then into the recently levelled piece of wood.
    • Take another screw then screw it into where it goes through the new piece of wood first, then into the other piece of wood that is glued other than than the recently unleveled piece of wood.
결론
작성자
1다른 기여자 명과 함께
Ubayy
회원 가입일: 09/17/23
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 16
전체 시간: 402
