주요 콘텐츠로 건너뛰기
How to Fix an Unstable Ikea Poang Chair
필요한 것
  1. How to Fix an Unstable Ikea Poang Chair, How to Fix an Unstable Ikea Poang Chair: 1 단계, 이미지 1개 중 1개
    • Start by removing the seat cushion from the frame.
  2. How to Fix an Unstable Ikea Poang Chair: 2 단계, 이미지 3개 중 1개 How to Fix an Unstable Ikea Poang Chair: 2 단계, 이미지 3개 중 2개 How to Fix an Unstable Ikea Poang Chair: 2 단계, 이미지 3개 중 3개
    • Remove the upper bolt, which attaches the back of the seat to the armrests.
    • Remove the lower bolt, which is the upper bolt attaching the seat to the legs.
    • Remove the same bolts on the opposite side of the chair.
    • To loosen the bolts, turn the Allen wrench to the LEFT, as shown in the video.
  3. How to Fix an Unstable Ikea Poang Chair: 4 단계, 이미지 1개 중 1개
    • Separate the back and seat of the chair from the legs and the armrest.
  4. How to Fix an Unstable Ikea Poang Chair: 5 단계, 이미지 2개 중 1개 How to Fix an Unstable Ikea Poang Chair: 5 단계, 이미지 2개 중 2개
    • Re-attach the bolts removed in Steps 2 and 3. Put each bolt into the correct location before tightening each bolt.
    • If the bolt attaching the seat tightens too easily, it is not in the hole and rests above or below the wood of the seat. This is what causes the tipping or dipping of the seat.
    • When attaching the bolt for the back of the chair, insert a plastic washer between the wood of the chair leg and the wood of the chair back. Without this washer, the two pieces will not sit flush. This allows the chair to shift and may cause the chair to become unstable.
    • For maximum stability, fully tighten all of the bolts in the chair.
    • As shown in the video, tighten by turning the Allen wrench to the RIGHT.
  5. How to Fix an Unstable Ikea Poang Chair: 7 단계, 이미지 1개 중 1개
    • Set the chair cushion on the chair seat.
    • Secure the Velcro on the cushion to the Velcro on the chair back.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Erik Romanski
회원 가입일: 03/30/16
191 평판
안내서 1개를 작성함
Michigan Tech, Team 1-21, Lauer Spring 2016 Michigan Tech, Team 1-21, Lauer Spring 2016 회원
MTU-LAUER-S16S1G21
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 29
지난 30일: 122
전체 시간: 17,304
