주요 콘텐츠로 건너뛰기
How to Fix an Unwinding Tape Measure
필요한 것
  1. How to Fix an Unwinding Tape Measure, How to Fix an Unwinding Tape Measure: 1 단계, 이미지 1개 중 1개
    • Grab your broken tape measure and inspect so that it doesn't retract.
    • Make sure it is not locked.
  2. How to Fix an Unwinding Tape Measure: 2 단계, 이미지 2개 중 1개 How to Fix an Unwinding Tape Measure: 2 단계, 이미지 2개 중 2개
    • Remove the four 3mm Phillips #1 screws on the case around the clip.
    • Remove the 3mm Phillips #1 screw from the center of the clip.
  3. How to Fix an Unwinding Tape Measure: 3 단계, 이미지 3개 중 1개 How to Fix an Unwinding Tape Measure: 3 단계, 이미지 3개 중 2개 How to Fix an Unwinding Tape Measure: 3 단계, 이미지 3개 중 3개
    • Separate the two halves of the case by pulling them apart.
  4. How to Fix an Unwinding Tape Measure: 4 단계, 이미지 2개 중 1개 How to Fix an Unwinding Tape Measure: 4 단계, 이미지 2개 중 2개
    • Begin unwinding your tape measure until you get to the end of the tape.
    • Remember to be careful when retracting so that the spring doesn't come out or you hurt someone when the whole tape is out.
  5. How to Fix an Unwinding Tape Measure: 5 단계, 이미지 2개 중 1개 How to Fix an Unwinding Tape Measure: 5 단계, 이미지 2개 중 2개
    • When the whole tape is out, slowly begin rolling it back in.
    • Roll it back in keeping your thumb firmly pressed on the wheel so that it goes back in smoothly and won't come out.
    • Once you start reaching the end, keep the tape straight with your thumb so that it retracts with no inconveniences.
  6. How to Fix an Unwinding Tape Measure: 6 단계, 이미지 2개 중 1개 How to Fix an Unwinding Tape Measure: 6 단계, 이미지 2개 중 2개
    • Once you have rolled the tape in again, place the top back on making sure the tape doesn't come out or roll out by itself.
    • Remember to keep your thumb on the wheel as you put on the top so that it doesn't come out and hurt anyone!
  7. How to Fix an Unwinding Tape Measure: 7 단계, 이미지 1개 중 1개
    • Begin placing the screws back in to their respective places and screwing them back in tightly.
    • Do this as you apply pressure on the top so that no parts come out.
  8. How to Fix an Unwinding Tape Measure: 8 단계, 이미지 1개 중 1개
    • Once your screws are back on, check your tape measure to see if it works properly or not.
    • If it isn't working the way you wanted to, repeat steps 2-7.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Lorena Sanabria
회원 가입일: 01/28/20
319 평판
안내서 1개를 작성함
2가이드 댓글
Wat te doen als de veer van het oprolmechanisme los is gekomen?
Adri - 답글
Heres the real solution for a tape that does not retract:
Disassemble until step 3
Roll out a bit of the tape
Roll it around the round thing with the spring in it once or twice (depends on how much retension you need) While holding the round thing in its position. Then reassemble. Done
Mortan Media - 답글
댓글 쓰기
조회 통계:
지난 24시간: 37
지난 7일: 280
지난 30일: 1,296
전체 시간: 68,401
