주요 콘텐츠로 건너뛰기
Troubleshooting iPhone X Face ID Not Working 'Move iPhone a Little Lower/Higher'
동영상 개요
  1. Troubleshooting iPhone X Face ID Not Working 'Move iPhone a Little Lower/Higher', Test The Flood Illuminator: 1 단계, 이미지 1/2 Troubleshooting iPhone X Face ID Not Working 'Move iPhone a Little Lower/Higher', Test The Flood Illuminator: 1 단계, 이미지 2/2
    • The phone keeps sending messages: ‘move iPhone a little lower/higher’ during the setting up process of Face ID. Based on REWA exclusive repair tricks, let’s start with the Flood Illuminator.
    • In our daily repair work, we can test the Proximity Sensor and the Ambient Light Sensor to confirm whether the Flood Illuminator is working normally.
    • Let’s make a phone call to confirm whether the Proximity Sensor is working. The Proximity Sensor works normally.
  2. Troubleshooting iPhone X Face ID Not Working 'Move iPhone a Little Lower/Higher', Test The Flood Illuminator: 2 단계, 이미지 1/1
    • Next, test the Ambient Light Sensor. The Ambient Light Sensor is also working normally.
    • Judging by this, the Face ID failure is not caused by Flood Illuminator.
  3. Troubleshooting iPhone X Face ID Not Working 'Move iPhone a Little Lower/Higher', Test The Front Camera Parts: 3 단계, 이미지 1/1
    • Let’s move on to the next step of Face ID troubleshooting – test the front camera parts.
    • Open the camera app and swipe to Portrait Mode. The background is not blurred, which is abnormal.
  4. Troubleshooting iPhone X Face ID Not Working 'Move iPhone a Little Lower/Higher', Observe The Dot Projector: 4 단계, 이미지 1/1
    • At the Portrait Mode, there is no flashing red light from the Dot Projector.
    • We can confirm now that the Dot Projector has malfunctioned.
    • This is the fault and the problem cannot be fixed.
    • The three parts ( infrared camera, flood illuminator and dot projector) are paired to the phone. Damage of any one of them can cause Face ID failure and such an issue is irreparable.
    Somebody pls help me .
    Bro, My XS screen just below the DOT PROJECTOR is flickering while unlocking the iPhone and while using Memoji ? Is it software issue ? I’m currently on iOS 14.2 .
    David Sunny - 답글
    Why can’t it be fixed
    Stephen Silvester - 답글
    Hello
    i have a problem with my iphone 12 pro max,the dot projector is not flashing while in portrait mode but it works,i mean the dot is start to light but not flashing is it software or hardware problem?if the dot proejctor was damaged it will be not working even with or without flashing?thanks
    aryanmhedin98 - 답글
    Hello, I have a question: all my sensors are working, but I still have the problem with the up-down. What can I do now?
    Tom Klingebiel - 답글
결론
다른 24명이 해당 안내서를 완성하였습니다.
Phryne
회원 가입일: 11/17/19
20,386 평판
안내서 18개 작성하였습니다
댓글 4개
Wieder mal traurig zu sehen was apple alles tut um die reperatur zu verteuern und drittreperaturshops zu blockieren.
Steven Pathman - 답글
how do you test the infrared camera? my face id is not working but everything chek out I thought the problem is the dot projector but it is working
justine mendoza - 답글
The title is How to fix and at the and it says can not be fixed :)))
nick_stylle - 답글
Here is a new method for fixing the dot projector. Apparently you may need multiple tag on flexes for it to work
https://www.youtube.com/watch?v=OnFCp9tt...
Kevin W - 답글
댓글 쓰기
조회 통계:
24 시간 전: 51
7일 전: 313
30일 전: 1,472
전체 시간: 179,001
