주요 콘텐츠로 건너뛰기
How to Fix the Fit of Eyeglasses
필요한 것
  1. How to Fix the Fit of Eyeglasses, How to Fix the Fit of Eyeglasses: 1 단계, 이미지 1개 중 1개
    • Assess the glasses and check the deformed areas (legs, temple tips, and nose).
  2. How to Fix the Fit of Eyeglasses: 2 단계, 이미지 1개 중 1개
    • Use a hair dryer to warm the temple tips.
    • Avoid overheating the frames. Moving the hair dryer ensures the heat is evenly distributed without damaging the plastic.
  3. How to Fix the Fit of Eyeglasses: 3 단계, 이미지 1개 중 1개
    • Gently bend and adjust the temple tips to your desired position.
    • Make sure the temple tips are bent just enough to fit securely behind your ears.
  4. How to Fix the Fit of Eyeglasses: 4 단계, 이미지 2개 중 1개 How to Fix the Fit of Eyeglasses: 4 단계, 이미지 2개 중 2개
    • Use the hair dryer and pliers to adjust the legs of the eyeglasses.
  5. How to Fix the Fit of Eyeglasses: 5 단계, 이미지 2개 중 1개 How to Fix the Fit of Eyeglasses: 5 단계, 이미지 2개 중 2개
    • Ensure the frame sits evenly and symmetrically on a flat surface.
    • If the frame does not sit evenly and wobbles, readjust the legs until satisfied.
  6. How to Fix the Fit of Eyeglasses: 6 단계, 이미지 2개 중 1개 How to Fix the Fit of Eyeglasses: 6 단계, 이미지 2개 중 2개
    • Adjust the nose pads using your thumb and fingers without applying heat.
    • Heating the nose pads is not necessary since they are malleable enough to be bent with small amounts of pressure.
    • Be careful not to over-bend the nose pads, as they can break if too much pressure is applied.
결론
By following these steps, you can easily restore the fit of your eyeglasses for increased comfort and stability. Minor adjustments like these not only save you a trip to a repair shop but also allow you to make precise changes tailored to your fit preferences. Remember to handle each adjustment with care, especially when using heat on plastic frames and applying pressure to metal frames, to avoid damage. With a little patience, this process will have your glasses feeling as good as new, letting you see clearly and comfortably throughout the day.
작성자
2다른 기여자 명과 함께
Dino Espineli
회원 가입일: 10/10/24
133 평판
안내서 1개를 작성함
UC Davis, Team 1-3, Morris Fall 2024 UC Davis, Team 1-3, Morris Fall 2024 회원
UCD-MORRIS-F24S1G3
2 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 54
전체 시간: 428
