주요 콘텐츠로 건너뛰기
How to Fix the Scroll Wheel of a Wired HP Mouse
필요한 것
  1. How to Fix the Scroll Wheel of a Wired HP Mouse, How to Fix the Scroll Wheel of a Wired HP Mouse: 1 단계, 이미지 1/1
    • Flip the mouse upside down and remove the screw on the bottom of the mouse casing using a Phillips #00 screwdriver.
  2. How to Fix the Scroll Wheel of a Wired HP Mouse: 2 단계, 이미지 1/1
    • Gently flip the mouse back over and remove the upper half of the mouse casing.
  3. How to Fix the Scroll Wheel of a Wired HP Mouse: 3 단계, 이미지 1/2 How to Fix the Scroll Wheel of a Wired HP Mouse: 3 단계, 이미지 2/2
    • Remove the broken axle that has become detached from the scroll wheel.
    • The broken axle may be difficult to locate, but should not have been able to leave the mouse casing unless it has previously been opened.
  4. How to Fix the Scroll Wheel of a Wired HP Mouse: 4 단계, 이미지 1/1
    • Carefully remove all circuit components from the mouse and set on a flat surface.
    • The circuit board is a single unit that should be able to be removed easily all at once.
  5. How to Fix the Scroll Wheel of a Wired HP Mouse: 5 단계, 이미지 1/1
    • Gently remove the scroll wheel by pulling it away from the rotary sensory mechanism.
    • The rotary sensory mechanism is the small green component of the circuit board that detects scrolling movement.
  6. How to Fix the Scroll Wheel of a Wired HP Mouse: 6 단계, 이미지 1/1
    • Place the scroll wheel inside the jaws of the basic pliers such that the broken side is facing up.
  7. How to Fix the Scroll Wheel of a Wired HP Mouse: 7 단계, 이미지 1/1
    • Holding the axle with a pair of small pliers, place a small amount of glue on the broken end of the axle.
    • Be careful to not get glue on yourself or any of the circuit components.
  8. How to Fix the Scroll Wheel of a Wired HP Mouse: 8 단계, 이미지 1/1
    • Place the axle on the scroll wheel in the position of best fit, and allow to sit for several hours to dry.
  9. How to Fix the Scroll Wheel of a Wired HP Mouse: 9 단계, 이미지 1/1
    • Return the scroll wheel to the rotary sensory mechanism.
    • The axle should sit over the middle mouse button input sensor which is directly across the circuit board from the rotary sensory mechanism.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
William Riley
회원 가입일: 10/19/20
169 평판
안내서 1개 작성함
Texas Tech, Team S14-G6, Cowan Fall 2020 Texas Tech, Team S14-G6, Cowan Fall 2020 회원
TTU-COWAN-F20S14G6
1 회원
안내서 3개 작성하였습니다
댓글 한 개
Props for the effort, but this will not hold for long, glued plastic will snap again soon.
bxsus - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 98
30일 전: 455
전체 시간: 11,514
