주요 콘텐츠로 건너뛰기
How to Fix the Side Pocket's Elastic on a Backpack
필요한 것
  1. How to Fix the Side Pocket's Elastic on a Backpack, How to Fix the Side Pocket's Elastic on a Backpack: 1 단계, 이미지 1개 중 1개
    • Trim any excess thread and frayed edges from the fabric with your scissors.
  2. How to Fix the Side Pocket's Elastic on a Backpack: 2 단계, 이미지 1개 중 1개
    • Stretch the elastic to match in length with the fabric.
  3. How to Fix the Side Pocket's Elastic on a Backpack: 3 단계, 이미지 1개 중 1개
    • Tuck the fabric edge back into the elastic.
  4. How to Fix the Side Pocket's Elastic on a Backpack: 4 단계, 이미지 1개 중 1개
    • Pin the fabric and elastic together.
    • Working with needles and pins can be dangerous.
  5. How to Fix the Side Pocket's Elastic on a Backpack: 5 단계, 이미지 1개 중 1개
    • Begin stitching the fabric and elastic together.
    • Start about one centimeter before the tear begins.
  6. How to Fix the Side Pocket's Elastic on a Backpack: 6 단계, 이미지 1개 중 1개
    • Continue stitching and remove pins when you sew past the part they're holding together.
  7. How to Fix the Side Pocket's Elastic on a Backpack: 7 단계, 이미지 1개 중 1개
    • Stitch until you have passed the end of the tear by about a centimeter.
  8. How to Fix the Side Pocket's Elastic on a Backpack: 8 단계, 이미지 1개 중 1개
    • End the stitch by tying a small knot close to where the thread passes through the fabric.
  9. How to Fix the Side Pocket's Elastic on a Backpack: 9 단계, 이미지 1개 중 1개
    • Cut the thread just above the knot so there is little excess.
  10. How to Fix the Side Pocket's Elastic on a Backpack: 10 단계, 이미지 1개 중 1개
    • Clean your work space and put away the tools
    • Congratulations, you're done!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Emily Burnside
회원 가입일: 09/29/15
155 평판
안내서 1개를 작성함
Cal Poly, Team 15-6, Green Fall 2015 Cal Poly, Team 15-6, Green Fall 2015 회원
CPSU-GREEN-F15S15G6
5 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 38
전체 시간: 9,426
