주요 콘텐츠로 건너뛰기
How to Fix the Worx Pegasus Workbench lower tray
필요한 것
  1. How to Fix the Worx Pegasus Workbench lower tray, Re-assemble per factory: 1 단계, 이미지 2개 중 1개 How to Fix the Worx Pegasus Workbench lower tray, Re-assemble per factory: 1 단계, 이미지 2개 중 2개
    • If yours became detached, make sure you begin by manually re-assembling the tray as it came from factory.
  2. How to Fix the Worx Pegasus Workbench lower tray, Drill through the hinge: 2 단계, 이미지 2개 중 1개 How to Fix the Worx Pegasus Workbench lower tray, Drill through the hinge: 2 단계, 이미지 2개 중 2개
    • Drill a small hole, the smallest possible but large enough to allow a zip tie to go through. I used a 1.5mm drill bit.
  3. How to Fix the Worx Pegasus Workbench lower tray, Route a Zip Tie: 3 단계, 이미지 2개 중 1개 How to Fix the Worx Pegasus Workbench lower tray, Route a Zip Tie: 3 단계, 이미지 2개 중 2개
    • Route a Zip Tie through the hole you just drilled and around the hinge barrel.
    • Cut the excess with scissors or wire cutters.
    • Do this procedure at least on two hinges: the leftmost and rightmost. For best results, address all six hinges.
  4. How to Fix the Worx Pegasus Workbench lower tray, Enjoy your reliable workbench: 4 단계, 이미지 1개 중 1개
    • If done correctly, the tray is not going to fail again.
    • This fix also adds a little bit more strength to the lower tray.
    • Enjoy!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
RodCastler
회원 가입일: 10/29/22
403 평판
안내서 2개를 작성함
2가이드 댓글
Nice job. Only critique is a better or close up of where you drill the holes for the zip ties. Hard to see from your pics. I figured it out and added all 6 to my hinges as that tray falls off non-stop. Thanks! I also added 4 other zip ties to the 4 small exterior holes on the outside of the tray that lock the perimeter attachment hinges into place as well.
Ray Wright - 답글
It wood be good to have some instructions on fitting and securing the outer hinges of the bottom tray
Tony Johnson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 37
전체 시간: 762
