주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Flatten a Folded Poster
필요한 것
  1. How to Flatten a Folded Poster, How to Flatten a Folded Poster: 1 단계, 이미지 2개 중 1개 How to Flatten a Folded Poster, How to Flatten a Folded Poster: 1 단계, 이미지 2개 중 2개
    • Open up the poster on a flat and clean surface and turn it over.
    댓글 쓰기
  2. How to Flatten a Folded Poster: 2 단계, 이미지 3개 중 1개 How to Flatten a Folded Poster: 2 단계, 이미지 3개 중 2개 How to Flatten a Folded Poster: 2 단계, 이미지 3개 중 3개
    • Wet a paper towel and wring most of the water out.
    댓글 쓰기
  3. How to Flatten a Folded Poster: 3 단계, 이미지 2개 중 1개 How to Flatten a Folded Poster: 3 단계, 이미지 2개 중 2개
    • Fold the damp paper towel and use it to lightly moisten the folds.
    • Doing this relaxes the fibers in the paper.
    댓글 쓰기
  4. How to Flatten a Folded Poster: 4 단계, 이미지 2개 중 1개 How to Flatten a Folded Poster: 4 단계, 이미지 2개 중 2개
    • Turn on the iron, and switch it to the warm mode or the lowest temperature.
    • Make sure to not use the vapor or steam settings.
    댓글 쓰기
  5. How to Flatten a Folded Poster: 5 단계, 이미지 2개 중 1개 How to Flatten a Folded Poster: 5 단계, 이미지 2개 중 2개
    • While the iron is warming up, take out any medium to use as an interleaving sheet.
    • The medium for the interleaving sheet can be a piece of cloth/paper/tissue/towel...etc.
    • Don’t put your iron in direct contact with the poster.
    댓글 쓰기
  6. How to Flatten a Folded Poster: 6 단계, 이미지 2개 중 1개 How to Flatten a Folded Poster: 6 단계, 이미지 2개 중 2개
    • Put the interleaving sheet of your choice on the folds, and move the iron across the sheet and poster gently as you work on all the folds.
    • Repeat on the other side as necessary.
    댓글 쓰기
  7. How to Flatten a Folded Poster: 7 단계, 이미지 2개 중 1개 How to Flatten a Folded Poster: 7 단계, 이미지 2개 중 2개
    • The End! You get a flat poster now!
    • After this treatment, the poster will become very flat and most of the creases can be removed. But some physical damage brought by folding may be difficult to be completely erased.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Manshu Liu
회원 가입일: 02/02/23
145 평판
안내서 1개를 작성함
UC Davis, Team 1-5, Andersen Winter 2023 UC Davis, Team 1-5, Andersen Winter 2023 회원
UCD-ANDERSEN-W23S1G5
2 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 101
지난 30일: 572
전체 시간: 23,153
