주요 콘텐츠로 건너뛰기
How to Force Restart an iPhone 5c
  1. How to Force Restart an iPhone 5c, How to Force Restart an iPhone 5c: 1 단계, 이미지 2개 중 1개 How to Force Restart an iPhone 5c, How to Force Restart an iPhone 5c: 1 단계, 이미지 2개 중 2개
    • Press and hold the Home button.
    • While holding the Home button, press and hold the Sleep/Wake button.
  2. How to Force Restart an iPhone 5c: 2 단계, 이미지 2개 중 1개 How to Force Restart an iPhone 5c: 2 단계, 이미지 2개 중 2개
    • Continue holding both buttons for about 10 seconds, until the Apple logo appears.
결승점
다른 81명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Dante Mazzanti
회원 가입일: 07/13/15
36,496 평판
안내서 26개를 작성함
6가이드 댓글
i have done this already and it still doesn't work someone please help me
ugotitmaid502 - 답글
Attention, la partie positionnement et mise en place des bandes adhésive est erronée pour deux raisons, la première est que le pack adhésif fourni est différent de celui apparaissent sur les photos . La deuxième est que la batterie utilisé pour les photos est celle d'origine Apple et non celle fournie dans le kit iFixit.! ! ! Autrement une fois installée, la batterie est opérationnelle . A tester sur du moyen terme / long terme .
denisrinzivillo - 답글
Cette remarque a-t-elle un rapport avec le redémarrage forcé d'un iPhone 5C ?
[deleted] -
The instructions will turn it off, yes. Then what’s the procedure for turning it back on? I have pressed one button or the other until the logo appears, but is there a proper button sequence? —Gil
Gil Dawson - 답글
I’m having the same problem!
Deborah Graves - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 69
전체 시간: 75,311
