소개
Use this guide to force restart your iPhone 6 when it is frozen and not responding. Force restarts are very simple and require no tools.
Press and hold the Home button.
While holding the Home button, press and hold the Sleep/Wake button.
Continue holding both buttons for about 10 seconds, until the Apple logo appears.
Thanks so much. I almost tried opening the phone to remove and reconnect the battery.
Hai Nguyen - 답글
when the apple logo appears still it's not turning on.
Awesome. It worked
jvn kalyan - 답글
Brilliant! No trip to the apple store for me. Big thanks!
I would recommend letting your battery go completely flat before you begin. I would imagine that there is less chance of a fire if the gets damaged while completely discharged compared to a fully charged battery. I bent my battery really out of shape extracting it. A scary moment. It was some comfort to me knowing it wasn’t carrying a lot of energy.
This may be the simplest thing anyone can do to an iPhone. But why did I see the recommendation to “backup your data” before attempting a hard restart? Is there ANY possibility this “simple” thing could go off-the-rails and render an iPhone that just underwent what appears to be an ultra-successful battery replacement could be brought low by this recommended final maneuver?
I wonder why it is not working on my mothers phone? It just keeps restarting, never shuts down and just restarts and immediately asks for passcode or thumbprint…..
I held the home an side button an nothing happenef
It didn't work on my
Help! After a hard reset the apple does not go away, phone is not working/turning on at all!
osuziq2001 - 답글
help it demands support .apple.com/iphone /restore what i can do right now
Asi batool - 답글
mine said the same thing …
now it’s back to a blinking apple
did you ever get it working??
please help, (anyone)
I get the APPLE symbol but nothing more?
Adobe Premiere Rush Mod APK Crack Add music and songs to videos for free in Adobe Premiere Rush APK mod.Use auto ducking, voice over and apply video effects to clips in your multitrack timeline with recommended video editor by influencers, vloggers and professionals. Crop the video screen to fit and share it right in the app with your favorite social sites like YouTube, Facebook, Instagram, and Behance. Use free with three exports or upgrade for unlimited sharing.
F-Secure Freedome VPN Crack This software does not log your traffic. Block unwanted third-party tracking and block malicious sites. At the expense of your privacy, it also prevents advertisers from making money. No one can intercept your traffic, it is encrypted no matter if you are using public Wi-Fi, it is completely insecure. After installing this software, you feel free as it is brand new software for your web protection as well as any online privacy solution.
FonePaw Android Data Recovery Crack at crackred is the name of powerful software to recover information and deleted files from Android devices. With an easy to use interface, you can use this software to recover deleted data from Android smartphones and tablets in no time. Have you accidentally lost some of the data on your Android device recently? Do not worry! Since Android Data Recovery is compatible with most Android devices and versions, it can accurately scan your device’s memory and recover all kinds of deleted data from your devices. adobe audition crack from keyslog
autocad 2019 crack from forcrack
Please help me
다른 489명이 해당 안내서를 완성하였습니다.
댓글 81개
I have an Iphone 6 which just broke in mid use. No GPS signal then freeses. Now it only goes as far as the apple logo. Tried to update and replace from a backup but nothing works. I havent goten it back but service says it needs replacement for 379Euros. Do you have any ideas on how to debug what needs to replaced? Mobo, something else maybe? does anybody know what IOS requires from the hardware to be able boot up? What post tests are there. The phone has always been in a lifeproof nuud case thats really robust and waterproof so I can't understand what could have gone wrong on this...
I have this problem my phone has been in service now for three months no progress
My iphone 6 shows "iphone disabled"
what do i do please??
same problem! help!
this doesn't work, i just use ReiBoot (iPhone restart freeware). enter recovery mode and exit restart my iphone 6s.
Thank you! Reiboot saved some tears today. Worked like a charm.
This worked for me,such an easy thing to do also
This is not working at all. My iPhone 6 won't charge up or come on. Just a black screen
THIS WORKED for ME . I have an iphone 6 from T-mobile Out of Nowhere i LOST my network connection to my plan. I went to T-mobile to request a New Sim Card hoping that would Fix the problem but it did not. I kept the New sim card and was planning to visit the Apple store to repair it.
I just tried THIS hard reset reboot and... now my Iphone is back connected to the Network. Thanks .
I recommend you guys Also try selecting "General" then "Reset" then select "Reset Network Setting" as well
DId you have an iphone 6 or no?
By force restarting your device, you would be resetting its current power cycle. Therefore, chances are that it might take you out of the problem you are facing. You can force restart your iOS device by pressing the correct key combinations for a few seconds.
If your iPhone/iPad stuck on Recovery/DFU Mode/Apple Logo, Etc.you can fix iPhone stuck in recovery mode after iOS 11 downgrade by force restart
This did not restart my phone. there was no response on phone when mentioned steps were followed. (my phone had frozen on home screen)
what finally restarted my phone was pressing power button on side and then pressing volume down button (keep pressing after volume lowered completely).
It worked for me, thanks a ton !
Srikrishna - 답글
it worked yes thank you so much! :)
it worked thank you so much! :)
what do i do if i have no home screen button? :)
I updated my iPhone6 to latest OS. It asked 4 a new passcode which was turned off, but I did 1-6 twice to confirm. It restarted all new and asked for my new 6 digit passcode to access phone. 1-6 did not work. AHHH!!!! OK, it says log into Apple ID. So I did, Apple id prompted a Code to enter to access account, that it sent to my locked phone. Nice. Great job guys. The phone now says disabled, the Apple ID is locked with two factor authentication. No way out…almost. I had an old phone that has issues, but will boot. Find another iphone or one to borrow. Swap the sim from one to the other. Re-login to Apple ID and get the code on the second phone. Once in, add other phones to account, turn off 2factor. Remove the disabled phone from the account if like mine, nothing will connect to it, reason is it needs updates according to itunes. Strange, a new update got me in this insane mess! What was it updating if not the software? Once removed, do a restore as directed. You need to wipe phone before u smash it-15hrs
Success! Just finished and iPhone 6 now works great again! Thanks iFixit!
Como un teléfono móvil inteligente, iPhone funciona de manera excelente, pero a veces ocurre un problema. “IPhone se sigue reiniciando” es una de esas cosas molestas. ¿Alguna vez te ha molestado que iPhone siga reiniciándose? ¿Quieres resolver el problema? El siguiente texto será una solución integral para ayudarte.
colinwhite - 답글
I got an iPhone 6 of gumtree but when it came I tried to set it up but there was still a password on it I tried to reset it but it won't work is there any other methods I could try.
I don’t seem to get the expected longer life out of the new battery as I did when my phone was new. I can’t even get a full days usage. My iPhone SE gets three times the life. Is there a way to fix this? I am on iOS 11.3
thank you for bringing me back to life from…cheeers
it doesnt work
Work! 15 seconds
WOOOWW I JUST UNLOCKED MY IPHONE 6S PLUS NOW WITH A TOOL A FRIEND OF MINE IN OK GAVE ME!! INBOX ME IF INTERESTED @ dannydheroe@gmail.com
Yes’m interested in how u rebooted your phone. My 6s just won’t charge or hard boot or show slider or apple signal Thank you ,
Can you help me out this is not wotking for me
A tech guy from this website: https://kotfx.com/pbuKl just helped me with this! It´s nice to ask through the website because if you have any further questions they can help you how many times you need.
I have an iphone 6 and i am locked out. Someone said from facebook they could unlock it for me, and i will not loose any data. As he works for apple. But he wants paying $100 for this. Just checked his profile and i see he only works in an apple store. Can my phone be reset without loosing all my data. I did not sync it with itunes before all this. Can i sync it now and save my data?
I have an iPhone 6s and all of a sudden it cut off and then the apple logo came on like its restarting but that's all it’s doing. The apple logo comes on then off and that's it what could be causing my iPhone 6s to do that?
Screen is just “flittering”, tryed to restart. But did not help - any advise please ??
Best regards
Michael Jensen
Seo-specialist
My phone is just stick on apple logo.
Done hard reset still not working.. kindly suggest
My iphone 6 is frozen and gives voice message. In enter passcode but it does not accept. Vijay Pawar
My iphone 6 is stuck. done hard reset. It is still not working. vijay pawar
j’ai tout essayer, mon iPhone 6 ne veut pas s’allumer, l’écran reste noir et rien ne se passe quand je le mets en charge
awsome help thankyou from a tech here in Aussie
THANK YOU!
Before I found your site, I was sure my iPhone 6 Plus was bricked. Now it’s updating with the status bar moving instead of being frozen. I recommend this article to anyone who thinks they have a bricked phone. -Scott
My iphone went off, hard reset and charging is not working. What can i do to turn it on
the top half don’t work how can i fix it
could you figure out how to get iPhone out of black screen only and it doesn’t respond”.
I need to get a new -
Hi please I have an iPhone6 stuck to iTunes logo I try to restore it but still not working I have the latest iTunes on my pc too but if I connect it and try to restore or update .. the apple logo will appear on the screen in which under the apple logo it will start to load under it but when it loads small it will no longer load again pls i need help or any other alternative to restore my iPhone thank you very much
If this doesn't work for you, don’t worry, it maybe the problem of your phone System.
Fucosoft iOS System Recovery is a professional iOS repair tool to fix various iOS issues like recovery mode, white Apple logo, black screen, etc. and get your iPhone back to normal (iOS 13 supported).
Download office setup with our help team without getting any work done by yourself. For more visit https://get-www-office.com here.
Microsoft Office install has required the removal of the previously installed version of your Office product on the device or system. Office 365 and other subscription offers various features, which you do not get when you do not purchase the Office product. The office can be used free, as Microsoft provides the trial versions of every tool. visit https://get-www-office.com/setup today.
Download Webroot Geek Squad Antiviurs If you own a device or system and you are connecting it to internet or another device then you must have antivirus software. Virus or any risky threat like Malware, Trojan, Spyware, Rootkit or online hacking or attack can steal your data and damage your system. click https://gewebroot.com today.
Makes the web safe for your kids to explore and helps your kids balance their time spent .. Internet Security Plus with Antivirus Protection by..... https://gewebroot.com/safe .
Mcafee Activate has recognized to be an effective way of keeping up your devices and your data safe from getting infected by any hackers and virus attackers. For more details visit https://gk-mcafee.com today.
With https://gk-mcafee.com/activate , you can prevent devices and network against threats like malware, worms, spyware and runs in the background and does not cause any problem nor slows down the computer.
To activate Hulu Plus on your device, either use the on-screen keyboard to enter your Hulu log in information or go to https://hulu-www-hulu.com and enter the device activation code. Either of these methods will allow you to use Hulu on any Hulu-supported device.
Hulu supports a wide variety of devices that you can use to stream with us. You can activate any of them at any time, as well as remove them from your account. click https://hulu-www-hulu.com/activate today.
Install mcafee antivirus in your computer with high class professionals and best tech team. Just ring us and we are ready to assist you till the last minute of installation - https://kc-mcafee.com today.
Mcafee offers you the McAfee activate option to give best Home network protection, Multi-device protection, Web Protection, and Identity Theft. visit https://kc-mcafee.com/activate today.
mcafee antivirus is widely used aantivirus helps to detect and neutralize computer virus, the mail worms,the trojan programs,and also helps your system free of virus and other malware is quite a daily challenge. for more details visit: https://mamcafee.com/activate today.
Install mcafee with activation code from https://mcafee25digitactivationcode.com . Activate mcafee with activation code to secure your windows and Mac Pc.
I have iPhone 6s screen just faded to nothing occasionally comes on with main figures then just rolls from the top of the screen in white to the bottom then nothing have tried force restart nothing happens
Tenorshare ReiBoot is a handy iOS repair utility that lets you easily access and exit the iPhone recovery mode without losing data. If your iPhone XR / XS / X / 8/7 / 7plus / 6s / 6s plus / 6 / 6plus / 5s / 5 is in recovery mode or in DFU mode when upgrading to iOS 12/11, this iOS system repair Tool the best software to get iOS back to normal with an intuitive user interface. Downloaded from HDLicense. In addition, even the solution is supported by more than 50 issues that occur on iOS without data loss, including the white Apple logo, the reboot loop of the iPhone, the black iPad screen, and iTunes errors, etc.
There were two brothers - Max and Felix. Once, Max wanted his brother to be taken away by unknown forces. And the irony of fate was terrible - a stupid idea embodied in reality. When Max realized what he had done, he armed himself with a marker and went on a journey in search of his own brother .. downloaded from Max The Curse Of Brotherhood HitPcGames
Plague Inc Evolved HitPcGames Download PC
Easeus Partition Master Crack Professional Edition combines three of the most important disk management utilities in one easy-to-use package. The partition manager performs all the important functions for formatting and managing the hard disk, but it can do much more, for example, B. B. Extend the NTFS disk partitions without rebooting. photocrack
Final Cut X Crack Import and edit everything from standard resolution to 8K video, including ProRes, ProRes RAW, and all major professional camera formats. Import and edit beautiful 360-degree videos with titles, graphics, 360-degree effects, and VR headset playback. Play high-resolution media up to 8 KB (or more) in full-screen mode or on a second screen.secrack
AnyTrans Crack from iOS to Android doesn't have to be a long or slow process. But it makes it easy for you. With one click, you can seamlessly transfer the most important content from iPhone, iTunes, and iCloud to your new Android phone.thiscrack
klklklkllkkklklk
I have iphone 6 it is automatically restarting while we talking wat is the problem
J’essaye d’allumer mon i phone ça affiche que la pomme que dois je faire
What we should do when I Phone 6 is disable
Ketharam M - 답글
So, my son was given an iPhone 6. Screen is not responding, but it is brand new. I did the reset with the home and sleep/awake button and got the Apple logo. However, I cannot swipe to set up his phone. Anyone have any insights?
My iPhone 6 Donnaye J icloud@gmail.com
So I was washing plate and while washing I was playing a video so I knew water might get to it so instead of using my hands to swipe I used my elbow then twenty minutes later I finished washing I was watching another video then it paused by itself then suddenly the screen stared to appear like blank I would say with those ash stuff surrounding the screen and it became frozen and so overheated after I tried switching it off
I forgot my apple id, icloud and my passcode because I had taken long without using my iphone 6. I got it fixed but it requires tge apple id so that I can finish setting it up and yet I have forgotten it all. Please I need help on how I can access my phone back as I bypass the apple id
which button is the sleep wake one i have i phone 5 se
Chris Ian Holmes - 답글
