주요 콘텐츠로 건너뛰기
How to Force Restart an iPhone 6s
  1. How to Force Restart an iPhone 6s, How to Force Restart an iPhone 6s: 1 단계, 이미지 1/2 How to Force Restart an iPhone 6s, How to Force Restart an iPhone 6s: 1 단계, 이미지 2/2
    • Press and hold the Home button.
    • While holding the Home button, press and hold the Sleep/Wake button.
  2. How to Force Restart an iPhone 6s: 2 단계, 이미지 1/2 How to Force Restart an iPhone 6s: 2 단계, 이미지 2/2
    • Continue holding both buttons for about 10 seconds, until the Apple logo appears.
    What do u do then it gust goes black and won't turn on
    Angelina Walker - 답글
    Another question. What to do when these force start instructions result in a dead black, unchanged screen?
    csrmclaughlin - 답글
    So I’ve replaced the screen but still have just a blank black screen, when I try turning it on it has the plug in and charge icon pops up, and goes off when I unplug, but nothin else will display on screen!!! HELPPPP!! PLEASE!!
    Marc Andriani - 답글
결승점
다른 276명이 해당 안내서를 완성하였습니다.
Evan Noronha
회원 가입일: 02/05/15
223,427 평판
안내서 168개 작성하였습니다
댓글 22개
Thank you! Thank you! This tip saved my day!
pamathis - 답글
I dropped my phone in the garage it locked my screen when I turn it on it has lines across real colorful but locked I m not able to retrieve contacts or photos from it…is there any hope,? I had to purchase another phone same one iPhone 6s I really need my contacts and photos from this phone?
atina1951 - 답글
my home button doesnt work, how do i do this without the home button?
Kennedy Truong - 답글
its not  working for me I been trying it and just did again any other suggestions when u have no ride
Amanda Wright - 답글
Swollen battery kept the home button from properly working on my phone, it spread the case apart slightly. Do you have battery problems?
Eric Andersen -
If the home button was malfunction, how to force restart?
Tseng Stanley - 답글
Brillant guide. Was my first time opening up an iPhone for repair. Guess what? It even works afterwards, which, I have to admit, is rarely the case when I try to fix something. Thanks
Karsten Fischer - 답글
Kit fit great. Be patient when installing. Would recommend
Danny Mosley - 답글
i did this with my phone and a bunch of grey lines appeared and then it went completely black and no logo came up?
haileyfarlow123 - 답글
It doesn't work
Vikas Wahi - 답글
It is just off, it doesn’t do anything, even I left it hooked for the hole day and it won’t even show the battery when charging. Is there any way to full reset? I do not even care anymore for what I have, I just want my phone back.
ronster65 - 답글
what if the homebutton does not work? Is there a way to restart then?
Sharon Held - 답글
i got so incredibly lucky. i actually misplaced two of the screws belonging to the panel that holds down the 3 display connector cables, saying “&&^& it” and only using the two at my disposal. fearing having to buy a new phone (having completed all the steps), i forced a restart and… it works perfectly. no common issues that i had seen in any of these comments. thanks so much!!
Jack Larson - 답글
Well done guide. Thanks.
Leon - 답글
et quoi faire si mon bouton home ne marche plus ?
Sara Bjd - 답글
Amazing trick! Last thing I needed was to get a new phone right now.
jgensib - 답글
on/off bottom on right hand side does not work after battery change
is there any possibility to make a hard reset?
on my mcbook in finder it is not possible
Kai Gundrum - 답글
Se queda la manzana a reiniciarlo y de ahi no pasa😢😢
Alejandro piña - 답글
솔직히 최신형 홈버튼 없는 iPhone이 강제 재시동은 편할 것 같네요..
Turtle - 답글
댓글 쓰기
조회 통계:
24 시간 전: 37
7일 전: 237
30일 전: 1,059
전체 시간: 274,911
