이 번역은 원본 안내서의 최신 업데이트를 반영하지 않을 수 있습니다. 번역 업데이트를 돕거나 아니면 원본 안내서 보기를 참조하세요.
소개
이 안내서를 사용하여 멈추거나 반응이 없는 iPhone 6s 기기를 강제 재시작하세요. 강제 재시작은 매우 간단하며, 도구가 필요없습니다.
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Press and hold the Home button.
While holding the Home button, press and hold the Sleep/Wake button.
Continue holding both buttons for about 10 seconds, until the Apple logo appears.
다른 276명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
50%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 25개
I dropped my phone in the garage it locked my screen when I turn it on it has lines across real colorful but locked I m not able to retrieve contacts or photos from it…is there any hope,? I had to purchase another phone same one iPhone 6s I really need my contacts and photos from this phone?
Hi,
I just logged into this website again and saw your comment. I wonder if the iPhone still has this issue. If it does, then maybe this can solve the issue. I just realized that I watched a YouTube video yesterday and in the video he has this issue and it came out that the cable that's connected to the screen got loose and it's causing this static glitch on the screen. He fixed it by reconnecting the cable and it was able to power on properly. I hope this helps 😁. U would need to take it to a repair shop to have it checked it could be the issue.
my home button doesnt work, how do i do this without the home button?
its not working for me I been trying it and just did again any other suggestions when u have no ride
