주요 콘텐츠로 건너뛰기
How to Format a drive in Windows 7-10
필요한 것
  1. How to Format a drive in Windows 7-10, Open File Explorer: 1 단계, 이미지 1/1
    • Open File Explorer.
    • You can do that from either of the red highlighted spots, or search for "File Explorer."
  2. How to Format a drive in Windows 7-10, Open the Format Menu: 2 단계, 이미지 1/2 How to Format a drive in Windows 7-10, Open the Format Menu: 2 단계, 이미지 2/2
    • Right-Click on the drive you want to format, and click format
    • This is what should pop up.
  3. How to Format a drive in Windows 7-10, Format your drive: 3 단계, 이미지 1/1
    • if you will be using the drive for Windows, format it as NTFS. If you need a multi-OS drive, exFAT or FAT32 is recommended. However, keep in mind FAT32 has a 4GB limit on files.
    • Use default allocation size.
    • If you want to rename your drive put the new name here.
    • Start the format. When It's done, you can close all the windows, and you are done.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
George A.
회원 가입일: 12/07/16
21,933 평판
안내서 4개 작성하였습니다
Community Protectors Community Protectors 회원
Community
19 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 17
30일 전: 87
전체 시간: 1,058
