소개
The following guide will help you to fix the CHP Mode Switch by taking off the back cover and cleaning around the switch.
부품
부품은 필요하지 않습니다.
  1. Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
    • Locate and remove two 6.4mm screws on the bottom of the camera with a Phillips #00 screwdriver.
  2. Locate the battery door.
    • Locate the battery door.
  3. Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
    • Locate the latch on the battery door marked by the word "BATT." Use your finger to pry it open.
  4. Remove the battery from the camera by pulling the battery door outwards.
    • Remove the battery from the camera by pulling the battery door outwards.
  5. Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
    • Locate and remove three black 3.80mm screws on the back of the camera with the Phillips #00 screwdriver.
  6. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  7. Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver. Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
    • Locate and remove the 6.4mm screws located on either side of the camera with a Phillips #00 screwdriver.
  8. Locate the film door latch located on the side of the camera.
    • Locate the film door latch located on the side of the camera.
    • Insert the spudger under the latch.
    • Caution: Be careful during the following step in order to not break any parts within the camera. Prying the latch in any other direction than perpendicular may result in broken parts.
    • Pry the latch upward, applying force perpendicular to the camera.
  9. Insert the flat edge of the spudger between the gold front casing and the black back casing.
    • Insert the flat edge of the spudger between the gold front casing and the black back casing.
    • Pry the spudger upward until the black back casing snaps out and is dislodged on that edge of the camera.
  10. Squeeze the camera by placing a thumb on the tab marked CE.
    • Squeeze the camera by placing a thumb on the tab marked CE.
    • Pull the back half of the camera firmly away from the camera body.
  11. Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
    • Locate and remove the 3.80mm screw inside the film compartment with the Phillips #00 screwdriver.
  12. Pull the front cover off of the camera by lifting the tripod tab over the tripod hole. Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
    • Pull the front cover off of the camera by lifting the tripod tab over the tripod hole.
  13. Locate the CHP Mode Switch.
    • Locate the CHP Mode Switch.
  14. Remove any visible debris that may be blocking the CHP Mode Switch.
    • Remove any visible debris that may be blocking the CHP Mode Switch.
    • Using the Q-tip gently wipe away any dust, dirt or residue, in and around the switch.
    • Once you are sure the switch is clean, test it gently by sliding it back and forth between the 'C', the 'H', and the 'P'. If the switch is clean there should be very little resistance and the switch should glide smoothly from one mode to the next.
결론
To reassemble your device, follow the instructions from the "Disassembling Fujifilm Endeavor 100ix Outer Casing" guide in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Eric Nicolai
회원 가입일: 2011년 01월 10일
679 평판
안내서 6개 작성하였습니다
Cal Poly, Team 13-5, Forte Winter 2011 Cal Poly, Team 13-5, Forte Winter 2011 회원
CPSU-FORTE-W11S13G5
5 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 1,839
