주요 콘텐츠로 건너뛰기
How to Grip a Hiking Pole
필요한 것
  1. How to Grip a Hiking Pole, Prepare the repair tools: 1 단계, 이미지 2개 중 1개 How to Grip a Hiking Pole, Prepare the repair tools: 1 단계, 이미지 2개 중 2개
    • Find a replacement grip tape to fix your pole.
    • Note: In this example we used the grip tape for tennis and badminton rackets.
  2. How to Grip a Hiking Pole, Prepare the grip tape: 2 단계, 이미지 3개 중 1개 How to Grip a Hiking Pole, Prepare the grip tape: 2 단계, 이미지 3개 중 2개 How to Grip a Hiking Pole, Prepare the grip tape: 2 단계, 이미지 3개 중 3개
    • Open the grip tape and look for the diagonal tip of the tape. Set aside the sticker wrap (green arrow). This will be useful for the final part of the repair.
    • Tip: in order to identify the right tip, put both ends side to side and look for the one that has a "diagonal" shape (orange arrow).
  3. How to Grip a Hiking Pole, Wrap the tape: 3 단계, 이미지 3개 중 1개 How to Grip a Hiking Pole, Wrap the tape: 3 단계, 이미지 3개 중 2개 How to Grip a Hiking Pole, Wrap the tape: 3 단계, 이미지 3개 중 3개
    • Remove the sticker back (red circle) of the tip and and begin to wrap the tape around the grip.
    • Make sure you begin at the end of the grip and start to wrap it upwards, keeping it tight at all times.
  4. How to Grip a Hiking Pole, Keep wrapping the grip: 4 단계, 이미지 3개 중 1개 How to Grip a Hiking Pole, Keep wrapping the grip: 4 단계, 이미지 3개 중 2개 How to Grip a Hiking Pole, Keep wrapping the grip: 4 단계, 이미지 3개 중 3개
    • Continue to wrap the tape around the grip until you reach the end of handle.
  5. How to Grip a Hiking Pole, Cut the tip of the tape: 5 단계, 이미지 3개 중 1개 How to Grip a Hiking Pole, Cut the tip of the tape: 5 단계, 이미지 3개 중 2개 How to Grip a Hiking Pole, Cut the tip of the tape: 5 단계, 이미지 3개 중 3개
    • Once you have reached the end of the grip, it is time to cut the end of the tip.
    • Follow the red line to cut it in a "diagonal shape".
  6. How to Grip a Hiking Pole, Close the new grip: 6 단계, 이미지 3개 중 1개 How to Grip a Hiking Pole, Close the new grip: 6 단계, 이미지 3개 중 2개 How to Grip a Hiking Pole, Close the new grip: 6 단계, 이미지 3개 중 3개
    • Use the sticker wrap that came with the tape to close the new grip and set it in place.
  7. How to Grip a Hiking Pole, Finished and ready!: 7 단계, 이미지 3개 중 1개 How to Grip a Hiking Pole, Finished and ready!: 7 단계, 이미지 3개 중 2개 How to Grip a Hiking Pole, Finished and ready!: 7 단계, 이미지 3개 중 3개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 398
