주요 콘텐츠로 건너뛰기
How to Hack Epson L200's Waste Ink Pad
필요한 것
  1. How to Hack Epson L200's Waste Ink Pad, How to Hack Epson L200's Waste Ink Pad: 1 단계, 이미지 1/2 How to Hack Epson L200's Waste Ink Pad, How to Hack Epson L200's Waste Ink Pad: 1 단계, 이미지 2/2
    • A wild Epson Printer appears.
    • Turn it around and look for a small door.
  2. How to Hack Epson L200's Waste Ink Pad: 2 단계, 이미지 1/2 How to Hack Epson L200's Waste Ink Pad: 2 단계, 이미지 2/2
    • Locate the small door on the back and open it.
    • You will find the tube that drains the waste ink to the ink pad.
  3. How to Hack Epson L200's Waste Ink Pad: 3 단계, 이미지 1/1
    • As you can see, the pad is full with waste ink and is larger than the small door that gives you access to it, meaning it is not meant to be changed by mortals.
  4. How to Hack Epson L200's Waste Ink Pad: 4 단계, 이미지 1/2 How to Hack Epson L200's Waste Ink Pad: 4 단계, 이미지 2/2
    • With a pair of tweezers gently pull the ink tube from the ink container.
    • Be careful not to grab it from the tube so as not to damage it.
  5. How to Hack Epson L200's Waste Ink Pad: 5 단계, 이미지 1/3 How to Hack Epson L200's Waste Ink Pad: 5 단계, 이미지 2/3 How to Hack Epson L200's Waste Ink Pad: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    구매
    • With the help of a syringe or anything that can suck liquid, clean the remaining ink from the tube.
    • I also went ahead and cleared the pad from as much ink as I could, it can buy you a bit more life span to the pad if you are in a hurry to print and not have the replacement items for this hack.
    • I did not have a syringe at the time and used a desolder pump, takes way longer though.
  6. How to Hack Epson L200's Waste Ink Pad: 6 단계, 이미지 1/2 How to Hack Epson L200's Waste Ink Pad: 6 단계, 이미지 2/2
    • Cut a 6" piece of the aquarium tubing and grab a connector.
    • Connect the printer tube to the aquarium tubing you just cut with the connector.
  7. How to Hack Epson L200's Waste Ink Pad: 7 단계, 이미지 1/1
    • Put a connector on the end of the aquarium tube and connect it to the top of the bottle. Make sure that there is no chance of spilling or else you will have a big black spot of ink under your printer.
    • I inserted another connector on the top side of the bottle to release any pressure created by the ink coming in and the air in the bottle.
  8. How to Hack Epson L200's Waste Ink Pad: 8 단계, 이미지 1/1
    • I placed the bottle in a lower elevation than the printer so that the ink can travel down the tube easier.
    • Check periodically to empty the waste ink bottle.
    Great idea. You are very smart)))
    Anar Farzaliyev - 답글
결론
다른 17명이 해당 안내서를 완성하였습니다.
Angela Penaherrera
회원 가입일: 05/06/13
12,565 평판
안내서 5개 작성하였습니다
댓글 13개
I have the same problem. I will try that step. Good instructions. Thank you.
Adi Priyono - 답글
Thanks for this! =) God bless!
CHRISTOPHER L. BIRUNG - 답글
i need the ressetter for an epson l310
thandolwenkosim - 답글
will this work on L220?
Andi Lesmana - 답글
anyone have try this?
eufrasiaaa - 답글
thank you very much it really helped me
Rupesh Gupta - 답글
Thank you for your guide
rsahirani - 답글
Epson l200 resetter adjustment software is a program to reset the waste ink pad counter on your printer. <a href="https://epsonadjprog.blogspot.com/2019/0... ">Epson L200 resetter</a> thank you
Priya Palukavali - 답글
The printer shall still generate waste ink counter (wic) how to reset the counter without buying the reset code.
bal_pk - 답글
you can use this waste ink to black tank again
Bikramdeep Singh - 답글
That was the easy part. The problem part is that the printer is keeping count of how many cleaning flushes it does, and at a certain number will stop printing until you either get a new one or reset the counter.
Keith Odom - 답글
Did you notice that I included information on your comment in the guide description? Other users also replied with information on how to reset the count. Hope that helps!
Angela Penaherrera -
Very Nice Thank you
srisrielango - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 27
30일 전: 134
전체 시간: 53,943
