주요 콘텐츠로 건너뛰기
How to Hand Sew Patches Onto a Garment
필요한 것
  1. How to Hand Sew Patches Onto a Garment, How to Hand Sew Patches Onto a Garment: 1 단계, 이미지 1개 중 1개
    • Place the cardboard separator in between the layers of your chosen garment.
    • This helps to avoid stitching both sides of the garment together.
  2. How to Hand Sew Patches Onto a Garment: 2 단계, 이미지 1개 중 1개
    • Choose a color of thread that matches or contrasts with the color of your patch.
  3. How to Hand Sew Patches Onto a Garment: 3 단계, 이미지 2개 중 1개 How to Hand Sew Patches Onto a Garment: 3 단계, 이미지 2개 중 2개
    • Choose where you’d like the patch to sit on the garment.
    • To help with stability, use pins and iron the garment to maintain the position of the patch.
  4. How to Hand Sew Patches Onto a Garment: 4 단계, 이미지 2개 중 1개 How to Hand Sew Patches Onto a Garment: 4 단계, 이미지 2개 중 2개
    • Push the thread through the eye of the needle.
    • To prevent fraying, twist the ends of the thread to tighten it.
  5. How to Hand Sew Patches Onto a Garment: 5 단계, 이미지 3개 중 1개 How to Hand Sew Patches Onto a Garment: 5 단계, 이미지 3개 중 2개 How to Hand Sew Patches Onto a Garment: 5 단계, 이미지 3개 중 3개
    • Insert the needle through the backside of the shirt and patch.
    • Pull the needle until the thread is taut.
    • Insert the needle through the outside of the shirt and patch, at the length you’d like your stitch to be.
    • Pull the needle again until the thread is taut.
  6. How to Hand Sew Patches Onto a Garment: 6 단계, 이미지 3개 중 1개 How to Hand Sew Patches Onto a Garment: 6 단계, 이미지 3개 중 2개 How to Hand Sew Patches Onto a Garment: 6 단계, 이미지 3개 중 3개
    • On the backside, insert the needle at a similar distance to the previous stitch, away from the previous stitch.
    • Insert the needle at the end of the previous stitch; this will be stitching backwards.
  7. How to Hand Sew Patches Onto a Garment: 7 단계, 이미지 3개 중 1개 How to Hand Sew Patches Onto a Garment: 7 단계, 이미지 3개 중 2개 How to Hand Sew Patches Onto a Garment: 7 단계, 이미지 3개 중 3개
    • Lace the needle through the extra fabric of the shirt that is covered by the patch.
    • Hold both ends of your thread and rotate it around the needle twice.
    • Create a loop using the thread and pull your needle through the loop.
    • Pull until the knot has formed (no extra thread is leftover).
    • Cut the thread with 1-2 inches to spare.
  8. How to Hand Sew Patches Onto a Garment: 8 단계, 이미지 1개 중 1개
    • Finished Product!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Shannon Ikemiya
회원 가입일: 04/24/24
178 평판
안내서 1개를 작성함
UC Davis, Team 2-1, Whithaus Spring 2024 UC Davis, Team 2-1, Whithaus Spring 2024 회원
UCD-WHITHAUS-S24S2G1
4 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 57
전체 시간: 418
