주요 콘텐츠로 건너뛰기
How to Hand Sew a Tear in Clothing
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. How to Hand Sew a Tear in Clothing, How to Hand Sew a Tear in Clothing: 1 단계, 이미지 1개 중 1개
    • Lay out your piece of clothing with the tear facing up and in sight on a flat surface.
    • A table is a good place for a work surface rather than your lap or the ground.
  2. How to Hand Sew a Tear in Clothing: 2 단계, 이미지 3개 중 1개 How to Hand Sew a Tear in Clothing: 2 단계, 이미지 3개 중 2개 How to Hand Sew a Tear in Clothing: 2 단계, 이미지 3개 중 3개
    • Cut a long piece of thread with the scissors.
    • Cut the length of the thread according to how long the tear is. For a 5 inch tear, cut about a 1.5 foot piece of thread. If you have excess thread at the end of the task, you can always cut the extra off. You cannot do so if you do not have enough thread to finish sewing.
    • Choose thread that matches the color of the material so that the thread blends in with the material, hiding the tear.
  3. How to Hand Sew a Tear in Clothing: 3 단계, 이미지 1개 중 1개
    • Tie a knot at one end of the thread.
  4. How to Hand Sew a Tear in Clothing: 4 단계, 이미지 1개 중 1개
    • Put the un-knotted end of the thread through the eye of the needle (the hole in the needle).
    • This step can be frustrating, but be patient. To make it easier, wet the end you are putting through the hole and flatten the thread with your fingers. Now try again.
    • Be careful while using the needle. It is pointy and sharp.
  5. How to Hand Sew a Tear in Clothing: 5 단계, 이미지 2개 중 1개 How to Hand Sew a Tear in Clothing: 5 단계, 이미지 2개 중 2개
    • To begin stitching:
    • Take the threaded needle in your fingers and place under one end of the tear with the needle pointing up.
    • Poke the needle through the left side of the tear and pull on the needle upward until the knot reaches the material and stops the thread from going any further upward.
  6. How to Hand Sew a Tear in Clothing: 6 단계, 이미지 2개 중 1개 How to Hand Sew a Tear in Clothing: 6 단계, 이미지 2개 중 2개
    • Turn the needle downward on the right side of the tear, poke a hole making the needle go through the hole with the thread following.
    • Poke hole on the underside of the left side of the tear.
    • Pull the needle slowly until the knot won't allow you to pull anymore.
  7. How to Hand Sew a Tear in Clothing: 7 단계, 이미지 1개 중 1개
    • Continue to stitch until the needle reaches the other end of the tear, making sure that the stitches are close enough together that the material from one end of the tear and the other end are sewn tightly together with little to no gaps.
  8. How to Hand Sew a Tear in Clothing: 8 단계, 이미지 3개 중 1개 How to Hand Sew a Tear in Clothing: 8 단계, 이미지 3개 중 2개 How to Hand Sew a Tear in Clothing: 8 단계, 이미지 3개 중 3개
    • When you get to the end of the tear, prepare to make a knot.
    • Make a small stitch but this time pull the needle upward through the loop formed and pull up until the loop closes. Do at least twice.
  9. How to Hand Sew a Tear in Clothing: 9 단계, 이미지 1개 중 1개
    • Cut the leftover thread off with the scissors so you are left with about an inch of thread dangling after the knot.
  10. How to Hand Sew a Tear in Clothing: 10 단계, 이미지 1개 중 1개
    • Your tear is now sewn together!
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
McKenzie Barlow
회원 가입일: 02/23/15
244 평판
안내서 1개를 작성함
Cal Poly, Team 12-2, Green Winter 2015 Cal Poly, Team 12-2, Green Winter 2015 회원
CPSU-GREEN-W15S12G2
6 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 1,548
