소개
It happens to all of us- you walk a little too close to a desk corner, or maybe you snag your clothes on a tree branch, and you’ve torn your shirt or pants. Don’t fret; there is a way to fix this! This document will offer step-by-step instructions on how to hand-sew a patch onto your clothes using recycled fabric.
필요한 것
Use your scissors to cut just outside the perimeter of the hole to clean the edges.
Center and place the patch over the hole.
Secure the top edge of your patch using straight stitch, ensuring to pull any access thread through along with the needle.
Make as many stitches as you need to reach the end of your patch, with your final needle position on the backside of your fabric.
You're all finished! To remove a patch, carefully use scissors or a seam ripper to cut only the thread used to secure the patch to the base fabric. Be cautious not to cut the fabric.
다른 한 분이 해당 안내서를 완성하였습니다.
