주요 콘텐츠로 건너뛰기
How to Hard Reset your HTC myTouch 3G
  1. How to Hard Reset your HTC myTouch 3G, How to Hard Reset your HTC myTouch 3G: 1 단계, 이미지 1/3 How to Hard Reset your HTC myTouch 3G, How to Hard Reset your HTC myTouch 3G: 1 단계, 이미지 2/3 How to Hard Reset your HTC myTouch 3G, How to Hard Reset your HTC myTouch 3G: 1 단계, 이미지 3/3
    • Start by turning off the phone.
    • Hold the Home and End keys for ten to thirty seconds, or until the home recovery display appears.
  2. How to Hard Reset your HTC myTouch 3G: 2 단계, 이미지 1/2 How to Hard Reset your HTC myTouch 3G: 2 단계, 이미지 2/2
    • Press the Home and End button once again to open the Recovery Options menu.
  3. How to Hard Reset your HTC myTouch 3G: 3 단계, 이미지 1/2 How to Hard Reset your HTC myTouch 3G: 3 단계, 이미지 2/2
    • Using the trackball, scroll to and select "wipe data/factory reset".
  4. How to Hard Reset your HTC myTouch 3G: 4 단계, 이미지 1/2 How to Hard Reset your HTC myTouch 3G: 4 단계, 이미지 2/2
    • Once the reset is complete, scroll back to "reboot system now".
결론
Warning: This process will wipe out any data on the phone.
다른 9명이 해당 안내서를 완성하였습니다.
Erik
회원 가입일: 09/17/12
96 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-9, Propen Fall 2012 Cal Poly, Team 2-9, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G9
3 회원들
안내서 10개 작성하였습니다
댓글 3개
this guide is soo good but my only problem is dat de scroll key is able to scroll through de options at the recovery page but unable to select. how do i select the "wipe data/factory reset option
David Mensah - 답글
i have the same problem, can you have a solution?
Raúl Torres Cázares -
Muchas gracias me ha servido mucho hace tiempo no trataba con estas reliquias que fueron la antesala de los equipos android de ahora
migueldan7 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 22,655
