주요 콘텐츠로 건너뛰기
How to Hem a Dress
필요한 것
  1. How to Hem a Dress, How to Hem a Dress: 1 단계, 이미지 2개 중 1개 How to Hem a Dress, How to Hem a Dress: 1 단계, 이미지 2개 중 2개
    • Begin with dress that is too long for the desired fit or style.
  2. How to Hem a Dress: 2 단계, 이미지 1개 중 1개
    • Lay the dress out flat, aligning the bottom seams.
    • Make sure any under layers are out of the way.
  3. How to Hem a Dress: 3 단계, 이미지 1개 중 1개
    • With a ruler, measure the amount you want the dress shortened.
    • After deciding, subtract 1" (25.4mm) from the seam allowance
    • (Ex: You want 3" (76.2mm) off, so you would measure 2'' (50.8mm) from the bottom of the fabric.)
  4. How to Hem a Dress: 4 단계, 이미지 1개 중 1개
    • Use chalk or pen to mark the measurement.
    • Make small dashed marks around the entire dress to ensure a consistent measurement.
  5. How to Hem a Dress: 5 단계, 이미지 1개 중 1개
    • Iron the dress flat.
  6. How to Hem a Dress: 6 단계, 이미지 1개 중 1개
    • Use scissors to cut vertically from the bottom seam to where you marked your measurement.
  7. How to Hem a Dress: 7 단계, 이미지 1개 중 1개
    • Then turn the scissors 90 degrees and begin cutting along the dashed lines you made in Step 4.
  8. How to Hem a Dress: 8 단계, 이미지 1개 중 1개
    • Then, again with the ruler and chalk measure 1/2'' (12.7 mm) from the raw edge of the fabric.
  9. How to Hem a Dress: 9 단계, 이미지 2개 중 1개 How to Hem a Dress: 9 단계, 이미지 2개 중 2개
    • Fold along the measurement you just made and iron it flat.
  10. How to Hem a Dress: 10 단계, 이미지 2개 중 1개 How to Hem a Dress: 10 단계, 이미지 2개 중 2개
    • Then fold again, one more time at 1/2''.
    • Lastly iron flat.
  11. How to Hem a Dress: 11 단계, 이미지 2개 중 1개 How to Hem a Dress: 11 단계, 이미지 2개 중 2개
    • Pin the fold in place.
    • Be careful when you pin.
  12. How to Hem a Dress: 12 단계, 이미지 1개 중 1개
    • If using a sewing machine, place it under the foot of the sewing machine.
    • Sew around the entire circumference of the dress.
    • Be careful when using a sewing machine.
  13. How to Hem a Dress: 13 단계, 이미지 3개 중 1개 How to Hem a Dress: 13 단계, 이미지 3개 중 2개 How to Hem a Dress: 13 단계, 이미지 3개 중 3개
    • Cut the threads and you're done!
결론
작성자
3다른 기여자 명과 함께
Juliette Price
회원 가입일: 02/02/24
217 평판
안내서 1개를 작성함
UC Davis, Team 3-5, Andersen Winter 2024 UC Davis, Team 3-5, Andersen Winter 2024 회원
UCD-ANDERSEN-W24S3G5
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 158
전체 시간: 1,271
