주요 콘텐츠로 건너뛰기
How to Hem a Skirt
필요한 것
  1. How to Hem a Skirt, How to Hem a Skirt: 1 단계, 이미지 1개 중 1개
    • Turn the garment inside out.
    • Inspect the hem: Are there any bulky regions along the hem or is it even all across? Is the hem straight or does it have curves?
  2. How to Hem a Skirt: 2 단계, 이미지 1개 중 1개
    • If your skirt has an existing hem, use seam ripper to remove current hem.
    • Place the pointed end in each stitch and cut it using the blade edge on the seam ripper.
    • Be sure not to rip the actual garment.
    • The example skirt did not have an existing hem.
  3. How to Hem a Skirt: 3 단계, 이미지 3개 중 1개 How to Hem a Skirt: 3 단계, 이미지 3개 중 2개 How to Hem a Skirt: 3 단계, 이미지 3개 중 3개
    • If the skirt is being shortened, wear the skirt inside out and measure the desired length.
    • Use sewing chalk to mark the length.
    • Pin up the fabric along the desired chalk line.
    • If you are only adding a hem, measure and fold 1/2 an inch up from the bottom of the skirt and pin along the edge.
    • You want to wear the skirt inside out so the hem is not on the outside of the skirt.
    • It may help to have a partner mark the desired length of the skirt while you are wearing it.
  4. How to Hem a Skirt: 4 단계, 이미지 3개 중 1개 How to Hem a Skirt: 4 단계, 이미지 3개 중 2개 How to Hem a Skirt: 4 단계, 이미지 3개 중 3개
    • Thread the needle with matching thread.
    • Start with a Backstitch to secure the thread.
    • Stitch along the hem, avoiding the pins.
    • Create a backstitch once you meet the place where you began.
    • For the example images, a darker thread was used for better visibility.
  5. How to Hem a Skirt: 5 단계, 이미지 2개 중 1개 How to Hem a Skirt: 5 단계, 이미지 2개 중 2개
    • Cut the thread to detach from needle.
    • Cut any excess thread.
  6. How to Hem a Skirt: 6 단계, 이미지 1개 중 1개
    • Turn the skirt right side out.
    • Inspect the hem to ensure there are no gaps.
    • Try on skirt for fit.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Safiah Nemr
회원 가입일: 02/01/24
157 평판
안내서 1개를 작성함
UC Davis, Team 1-3, Andersen Winter 2024 UC Davis, Team 1-3, Andersen Winter 2024 회원
UCD-ANDERSEN-W24S1G3
3 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 33
전체 시간: 471
