주요 콘텐츠로 건너뛰기
How to Identify Your Apple Watch
필요한 것
  1. How to Identify Your Apple Watch, How to find the series: 1 단계, 이미지 1개 중 1개
    • To find the series of your Apple Watch...
    • Turn the watch over so that you're looking at its back cover and the screen faces away from you.
    • The series number is engraved on the back cover, in small text.
    • The series is listed with other information such as the watch’s size and materials.
  2. How to Identify Your Apple Watch, How to find the model number on the watch: 2 단계, 이미지 3개 중 1개 How to Identify Your Apple Watch, How to find the model number on the watch: 2 단계, 이미지 3개 중 2개 How to Identify Your Apple Watch, How to find the model number on the watch: 2 단계, 이미지 3개 중 3개
    • To find the model number of your Apple Watch...
    • Remove the wristband from the watch. Press the button on the back case to slide the band out.
    • The model number is engraved where the band is held.
    • The model number starts with the letter 'A' followed by four digits (e.g. A1757).
  3. How to Identify Your Apple Watch, How to find the model number in the settings: 3 단계, 이미지 3개 중 1개 How to Identify Your Apple Watch, How to find the model number in the settings: 3 단계, 이미지 3개 중 2개 How to Identify Your Apple Watch, How to find the model number in the settings: 3 단계, 이미지 3개 중 3개
    • If you can't read the engraved text on the watch or don't want to remove the band, the model number can be found in iOS settings.
    • Open the Watch app on your iPhone and select the "My Watch" tab.
    • Select General > About and then scroll to the "Model" field. A number will be displayed as a combination of letters and numbers starting with “M”.
    • Tap the "Model" field. You should see the model number which starts with “A” (e.g. A2473).
  4. How to Identify Your Apple Watch, Apple Watch (Original) - April 2015: 4 단계, 이미지 3개 중 1개 How to Identify Your Apple Watch, Apple Watch (Original) - April 2015: 4 단계, 이미지 3개 중 2개 How to Identify Your Apple Watch, Apple Watch (Original) - April 2015: 4 단계, 이미지 3개 중 3개
    • Model Numbers
    • A1553 (38mm)
    • A1554 (42mm)
    • The back cover is composite, with "Composite Back" and “7000 series” text written on it.
  5. How to Identify Your Apple Watch, Apple Watch Series 1 - September 2016: 5 단계, 이미지 1개 중 1개
    • Model Numbers
    • A1802 (38mm)
    • A1803 (42mm)
    • Apple took their original Apple Watch, slapped in a faster processor, and called it the Series 1.
    • Composite back with 'Series 1' written on it.
  6. How to Identify Your Apple Watch, Apple Watch Series 2 - September 2016: 6 단계, 이미지 2개 중 1개 How to Identify Your Apple Watch, Apple Watch Series 2 - September 2016: 6 단계, 이미지 2개 중 2개
    • Model Numbers
    • A1757 (38mm)
    • A1758 (42mm)
    • A1816 (38mm)
    • A1817 (42mm)
    • Similar design to previous models but with the addition of built-in GPS. The back cover is ceramic, with 'Ceramic Back' and 'Series 2' written on it.
  7. How to Identify Your Apple Watch, Apple Watch Series 3 - September 2017: 7 단계, 이미지 3개 중 1개 How to Identify Your Apple Watch, Apple Watch Series 3 - September 2017: 7 단계, 이미지 3개 중 2개 How to Identify Your Apple Watch, Apple Watch Series 3 - September 2017: 7 단계, 이미지 3개 중 3개
    • Model Numbers
    • A1858 (38mm GPS)
    • A1859 (42mm GPS)
    • A1860 (38mm GPS + Cellular)
    • A1861 (42mm GPS + Cellular)
    • Apple introduced a red dot on the Digital Crown if a GPS + Cellular model.
    • GPS-only models: the back cover is composite, with 'Composite Back' and 'Series 3' written on it.
    • GPS + Cellular models: the back cover is ceramic, with 'Ceramic Back' and 'Series 3' written on it.
  8. How to Identify Your Apple Watch, Apple Watch Series 4 - September 2018: 8 단계, 이미지 3개 중 1개 How to Identify Your Apple Watch, Apple Watch Series 4 - September 2018: 8 단계, 이미지 3개 중 2개 How to Identify Your Apple Watch, Apple Watch Series 4 - September 2018: 8 단계, 이미지 3개 중 3개
    • Model Numbers
    • GPS Only
    • A1977 (40mm), A1978 (44mm)
    • GPS + Cellular
    • A1975 (North America, 40mm), A2007 (Europe, Asia Pacific, and China mainland, 40mm) A1976 (North America, 44mm), A2008 (Europe, Asia Pacific, and China mainland, 44mm)
    • GPS + Cellular models feature a red ring on the Digital Crown.
    • Features a thinner body compared to the previous series.
    • The back cover is black ceramic with 'Series 4' written on it.
  9. How to Identify Your Apple Watch, Apple Watch Series 5 - September 2019: 9 단계, 이미지 3개 중 1개 How to Identify Your Apple Watch, Apple Watch Series 5 - September 2019: 9 단계, 이미지 3개 중 2개 How to Identify Your Apple Watch, Apple Watch Series 5 - September 2019: 9 단계, 이미지 3개 중 3개
    • Model Numbers
    • GPS Only
    • A2092 (40mm), A2093 (44mm)
    • GPS + Cellular
    • A2094 (North America, 40mm), A2156 (Europe, Asia Pacific, and China mainland, 40mm), A2095 (North America, 44mm), A2157 (Europe, Asia Pacific, and China mainland, 44mm)
    • Similar design to Series 4, but introduces the Always-On display.
    • The back cover is black ceramic, with 'Series 5' written on it.
  10. How to Identify Your Apple Watch, Apple Watch SE - September 2020: 10 단계, 이미지 2개 중 1개 How to Identify Your Apple Watch, Apple Watch SE - September 2020: 10 단계, 이미지 2개 중 2개
    • Model Numbers
    • GPS Only
    • A2351 (40mm), A2352 (44mm)
    • GPS + Cellular
    • A2353 (North America, 40mm), A2354 (North America, 44mm), A2355 (Europe, Asia Pacific, China mainland, 40mm), A2356 Europe, Asia Pacific, China mainland, 44mm)
    • Similar design to Series 4 and 5, but lacks the Always-On display.
    • The back cover is ceramic, with 'SE' written on it.
  11. How to Identify Your Apple Watch, Apple Watch Series 6 - September 2020: 11 단계, 이미지 3개 중 1개 How to Identify Your Apple Watch, Apple Watch Series 6 - September 2020: 11 단계, 이미지 3개 중 2개 How to Identify Your Apple Watch, Apple Watch Series 6 - September 2020: 11 단계, 이미지 3개 중 3개
    • Model Numbers
    • GPS Only
    • A2291 (40mm), A2292 (44mm)
    • GPS + Cellular
    • A2293 (North America, 40mm), A2294 (North America, 44mm), A2375 (Europe, Asia Pacific, China mainland), A2376 (Europe, Asia Pacific, China mainland)
    • Very similar design to Series 5, but introduces a Blood Oxygen sensor.
    • The back cover is ceramic, with “Series 6” written on it.
  12. How to Identify Your Apple Watch, Apple Watch Series 7 - October 2021: 12 단계, 이미지 2개 중 1개 How to Identify Your Apple Watch, Apple Watch Series 7 - October 2021: 12 단계, 이미지 2개 중 2개
    • Model Numbers
    • GPS Only
    • A2473 (41mm), A2474 (45mm)
    • GPS + Cellular
    • A2475 (North America, 41mm), A2477 (North America, 45mm), A2476 (Europe, Asia Pacific, China mainland, 41mm), A2478 (Europe, Asia Pacific, China mainland, 45mm)
    • Very similar design to Series 6 with the Blood Oxygen sensor.
    • The back cover is ceramic, with “Series 7” written on it.
  13. How to Identify Your Apple Watch, Apple Watch Series 8 - September 2022: 13 단계, 이미지 2개 중 1개 How to Identify Your Apple Watch, Apple Watch Series 8 - September 2022: 13 단계, 이미지 2개 중 2개
    • Model Numbers
    • GPS Only
    • A2770 (41mm), A2771 (45mm)
    • GPS + Cellular
    • A2772 (41mm North America), A2773 (41mm Europe, Asia Pacific), A2774 (45mm North America), A2775 (45mm Europe, Asia Pacific), A2857 (41mm China mainland), A2858 (45mm China mainland)
    • Very similar design to Series 7 with the Blood Oxygen sensor.
    • The back cover is ceramic, with “Series 8” written on it.
  14. How to Identify Your Apple Watch, Apple Watch SE (2nd Gen) - September 2022: 14 단계, 이미지 1개 중 1개
    • Model Numbers
    • GPS Only
    • A2722 (40mm), A2723 (44mm)
    • GPS + Cellular
    • A2724 (Europe, Asia Pacific, 44mm), A2725 (Europe, Asia Pacific, 40mm)
    • A2726 (North America, 40mm), A2727 (North America, 44mm)
    • A2855 (China mainland, 40mm), A2856 (China mainland 44mm)
  15. How to Identify Your Apple Watch, Apple Watch Ultra (GPS + Cellular) - September 2022: 15 단계, 이미지 2개 중 1개 How to Identify Your Apple Watch, Apple Watch Ultra (GPS + Cellular) - September 2022: 15 단계, 이미지 2개 중 2개
    • Model Numbers
    • A2622 (North America, 49mm)
    • A2684 (Europe, Asia Pacific, 49mm)
    • A2859 (China mainland, 49mm)
    • The crown has an orange ring on it.
    • It is a larger and more rugged watch than previous models and can be identified by “Watch Ultra” written on the back.
    • There are 4 visible pentalobe screws on the back.
결론
  • If you see a red dot, red ring, or orange ring on the Digital Crown you have a GPS + Cellular model.
  • You can find the model number by removing the wrist strap or in the general iOS settings.
  • You can find the series on the back of the watch.
  • There are special Hermès and Nike versions of most of these watches which can be identified by their logos.
작성자
3다른 기여자 명과 함께
Evan Gattuso
회원 가입일: 09/13/21
10,821 평판
안내서 1개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,629개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 60
지난 30일: 277
전체 시간: 6,683
